03-22-2011, 02:28 PM   #16
No noise on mine with Ev. I'm also curious whether this a K lens that will only shoot wide open.
The main thing is, with anything before Pentax M lenses, the camera is incapable of changing the aperture of the lens because the lens can't do it. There is nothing "electrically connected" to change the manually set (by hand) aperture of, let's say, a Super Takumar.
All the cam can do is change ISO and shutter speed for correct metering.
True but a "K" lens is designed to be focused wide open. Even if your lens is set to f/8 (or f/22 for that matter) you focus wide open because there is so much more light that way. When you push the green or e/v button the camera does 2 things. 1 the camera stops down the lens to the aperture you set (by moving the small tab on the back of the lens) and 2. It takes a reading at that aperture. You are then able to take your photo. There is no electrical connection but there is a mechanical one.
NaCl(clever people these Japanese)H2O
03-22-2011, 02:30 PM   #17
Are you guys telling me that the mirror has to flip up for metering on the K-x?
No that was my bad. That is what you get when you are trying to do 5 things at the same time. I apologize.
NaCl(there is nothing so much fun as monitoring a field modification, ordering parts and trying to post on PF at the same time)H2O
03-22-2011, 02:33 PM   #18
Hmm ... I seem to recall that the k-x does not bother to operate the aperture lever when green button metering in M-mode if the lens has a non-conductive base.
03-22-2011, 02:34 PM   #19
The little metal tab works okay, smooth and easy to move, this is what the camera body lets go of to stop it down I guess?
If I look directly down the lens I can see it's held open (I can see the mirror clearly) and when I press the shutter I can see it stop down to take the picture. There is also a large brightness difference in two pictures taken with the same settings with the apature ring set differently so it's definitely working in this regards.
03-22-2011, 02:37 PM   #20
QuoteOriginally posted by jolepp Quote
How does it work then? I know that the lens focuses wide open, I haven't shot with a manual lens in a while with my K-x, but I don't ever remember it focusing while stopped down. Will it work only with the e/v button?
NaCl(even I'm confused now)H2O
03-22-2011, 02:38 PM   #21
It does not have to but for some reason it does if a lens has a conductive base and the auto pin is not shorted (or so I would recall ).
03-22-2011, 02:39 PM   #22
QuoteOriginally posted by Chonker Quote
OK take a picture of a bright scene at f8 or so and see if it comes out. If you don't have anything else shoot at a relative bright lamp.
NaCl(it should work)H2O
03-22-2011, 02:43 PM   #23
That sounds like it could be the trouble then.
These are the two lenses I've tried, the one on the left is the new one which I'm having troubles with.
03-22-2011, 03:05 PM   #24
Yup, the one on the left seems to have a painted / coated base which would do it. The logic of this escapes me . Some people report using a piece of aluminium tape at the base to short the contacts as a chromed base would. Slipping a piece of aluminium foil in there when mounting the lens so that it shorts the contacts could be used verify whether this is about the contacts being shorted (I would further recall that shorting any of them would make a difference).
03-22-2011, 03:05 PM   #25
The black surface is definitely not conductive (had a go at it with a multi-meter). Now I'm wondering if strategically placed aluminised tape would fix that, is there a diagram anywhere explaining what the different pins on the lens do? (so i can avoid exploding anything)
03-22-2011, 03:05 PM   #26
Chonker, try Ira's method of pusing the e/v button instead of the green button. I know that one of the two works as I took a bunch of shots last fall with the K-x and the Pentax K 125 f2.5 they all came out pretty much perfectly metered.
NaCl(even tho it was kinda dark and I was shooting at 3200 iso)H2O
03-22-2011, 03:08 PM   #27
Shorting the pins is what happens with a chromed base (M/K lenses) so there should be no harm in it. This should explain pin functions: Features and Operation of the Ka Mount.
03-22-2011, 03:09 PM   #28
The pins should just ground out, just as if you had a chromed base.
NaCl(they can't do anything anyway with a completely manual lens)H2O
03-22-2011, 03:10 PM   #29
is that the button with the +/- symbol, I've tried and it does nothing either (no noises or change in shutter speed at different apertures)
03-22-2011, 03:31 PM - 1 Like   #30
Success!
Bit of aluminium tape did the trick, it's a little stiff to mount the lens but meters a treat Looking forward to a nice day to give this a go, if it's any good it'll be a proper bargain.
Thanks for all your help, that's a neat bit of knowledge to have about the metallic bases!
aperture, button, camera, lens, pentax help, photography
Manual lens does not stop down when metering or shooting. FH_le Pentax SLR Lens Discussion 5 01-21-2011 01:23 PM
stop down metering? jonhock Troubleshooting and Beginner Help 8 01-01-2010 04:00 PM
K-x Stop-down metering with m-42 lenses Bazwell Pentax DSLR Discussion 8 11-20-2009 12:57 PM
*istD and stop-down metering pocky Pentax DSLR Discussion 6 06-20-2009 01:02 PM
stop-down metering and Av mode Beau Pentax DSLR Discussion 15 06-02-2009 09:58 PM
All times are GMT -7. The time now is 02:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
