03-29-2011, 06:02 PM   #16
Coeurdechene's Avatar
Did the screw get deformated? if not you need a good presition screwdriver and some force...if it got deformated..well that makes things tougher (try gently with a good screwdriver, if it does not work you would have to make a line to use a flat one).
I've read about other ways to deal with the pin, some have cut it, some have dremeled it (kind of a risky solution...), or the alternative i like the most:
carefully put a small amount of superglue while pushing the pin down to hold it there.
03-30-2011, 05:45 AM   #17
yes, the cross part of the phillips screwhead is just a smoothed hole , nothing to grab, luckily it was a not great lens, i could try the superglue, hopefully when i get back the 135mm lens that is stuck on the camera, i can take the screws out and remove the pin, that one seemed like a good lens. thanks for your help.
03-30-2011, 02:51 PM   #18
QuoteOriginally posted by dh4412 Quote
Do yourself a favor and go buy a new screwdriver of the proper size. Expect to pay about 3-5 bucks for that tiny little rascal at a real hardware store. The crap they sell at the BORG will ruin a screw every time.
camera, lens, pentax, pentax help, photography
Lens stuck on camera - Help please! dompel Troubleshooting and Beginner Help 14 03-17-2011 05:55 AM
Help! m42 adapter stuck on camera ADHWJC Pentax SLR Lens Discussion 8 09-23-2010 12:23 PM
Help!! Vivitar teleconverter stuck on my camera :-( annod Pentax SLR Lens Discussion 5 10-04-2009 10:33 PM
lens stuck on camera dalechuk Pentax SLR Lens Discussion 4 05-05-2008 05:42 AM
Lens stuck on camera - Help! Finn Pentax SLR Lens Discussion 2 06-07-2007 11:01 AM
All times are GMT -7. The time now is 07:11 AM. | See also: NikonForums.com, part of our network of photo forums!
