03-26-2011, 10:47 AM   #1
copying pictures and slides
Have already copied all the old family photos with the Panasonic fz 15 that I have had for years,turned out good for most of then not so well for others.Bought a Bower slide duplicator and started on the slides and thought they could be done better which is one of the reasons for me changing to dslr to try for better results.Wonder if the results would be better if I bought a duplicator that fit the camera lens mount as the Bower fits in the filter threads of a lens?Have a 1000 or so slides to copy,don't have a scanner as we have no real use for one.
Jake
03-26-2011, 12:28 PM   #2
BirdDude007's Avatar
I too am looking for an adapter or something that I can attach to my camera so that I can digitize my negs and slides, I don't trust those all in ones that sell for around 100 bucks that you just feed your negs and slides into and it copiesw them
03-26-2011, 03:22 PM   #3
GerryL's Avatar
Slides are easy to copy with attachments for DSLRS.
These are mostly bellows with slide copier attachments.
Negatives on the other hand are harder since they are, well..negatives..some sort of reverse image colors.
5 megapixels are the usual output of those scanners.
Some go as low as around $70.
It's not something that will break the bank and copying would be easier for negs.
03-27-2011, 02:24 AM   #4
steve1307's Avatar
If you dont particluarly like the $100 all in one type scanners and are looking for better results consider one of these.
Plustek OpticFilm 7600i SE Scanner 60-A29-BBM310-C B&H Photo
Its a proper film scanner. $310.
This version has an infrared scan to detect scratches & dust on the slides.
My 77 year old father is scanning 1000's of slides & negs from the 50's, 60's & 70s. With the model below this one (without the IR) and has acheived some pretty decent results for his liking.
I had few trial runs to set up the software for them and the output was better than I had hoped for the money it cost.
It comes with Silverfast software if you want to use it for corrections. If you dont like you can allways use Vuescan.
Once you are finished with it, sell it or give it to a family member.
bower, camera, duplicator, pentax help, photography, slides
Lighting for copying slides to K10D jonhock Digital Processing, Software, and Printing 7 10-06-2010 08:59 PM
Trouble copying pictures off memory card james_k_p Troubleshooting and Beginner Help 15 04-05-2010 11:43 AM
Slide copying... off screens Rick Digital Processing, Software, and Printing 2 08-28-2009 04:08 PM
copying photo's in lightroom 5teve Digital Processing, Software, and Printing 5 06-21-2009 08:02 PM
Copying Slides edumad Photographic Technique 7 12-22-2008 09:51 AM
All times are GMT -7. The time now is 11:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
