04-01-2011, 05:04 AM   #1
Whitewashed faces on photos
Hi!
I am newbie KX user from India.
Lately (and this was not happening earlier) I find the faces to come out absolutely whitewashed whenever I use Flash in any mode while shooting in low light conditions.
Can anyone help me on this ?
04-01-2011, 05:16 AM   #2
jolepp's Avatar
This would happen with a manual lens (pre A-series) or a manual (no pttl, old, cheap or both) flash. If it this happens with a more modern lens than the M-series and a pttl flash (such as the built-in) posting sample snaps *with* EXIF info would most likely help in figuring out the problem.
04-01-2011, 05:36 AM   #3
aurele's Avatar
try to reduce the power of the Flash ( press the flash icone, use the wheel to push it to -0.3 EV or -0.5, it would be better.
04-01-2011, 08:33 AM   #4
DaveHolmes's Avatar
QuoteOriginally posted by aurele Quote
Aggree with this advice and add the use of a home-made defuser... (35mm film can... Black duct-tape over the back so you're not blinded... Cut a slot out to fit over the onboard flash...)
04-02-2011, 09:41 AM   #5
QuoteOriginally posted by bhaven Quote
Hi!
If you're in a dimly lit room using "Matrix" metering then the camera/flash is going to compensate for the darkness, and most likely will wash out any subject closer to the front of camera.
I would try to change metering pattern to center weighted or even spot, meter a face, use your AE lock, compose and shoot...
Good luck, Rick
04-02-2011, 10:21 PM   #6
Thanks everyone for your help - reducing the power of the Flash was the first thing I tried and it worked.
Thanks a zillion again.
People faces of baseball dcmsox2004 Post Your Photos! 6 08-19-2010 05:53 AM
People Faces in the Street fractal Post Your Photos! 4 07-02-2010 02:20 AM
Travel Faces in Papua New Guinea Mike L Post Your Photos! 9 06-19-2010 05:30 AM
Blown out faces in concert photos mindglow Troubleshooting and Beginner Help 17 04-30-2010 09:34 PM
Puppy Faces Workingdog Post Your Photos! 10 06-02-2009 08:25 AM
All times are GMT -7. The time now is 05:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
