04-04-2011, 10:49 AM   #1
bluebronco's Avatar
Wireless Trigger help
Hello,
I have a K20D and a Promaster 7500EDF flash. I want to make the jump into wireless triggering. I have read up on the articles here and I am a little lost.
Can someone point me to an affordable trigger with 1 or 2 receivers? I looked on eBay and am even more confused
Has any tried these:
eBay link
Will everything be shot in manual?
After doing a search, I know this has been hashed out, but the more I read the more confussed
Thanks for your help!
04-04-2011, 11:26 AM   #2
imtheguy's Avatar
GadgetInfinity.com. The new V5 transceivers are a fine low cost set but if budget is bigger concern, they still sell the V4 for less. There are dozens of reviews on the Cactus transceivers so you will have no trouble finding more info. I have 4 of the V5 and use them for remote shutter as well as remote flash with a K20K and a K-5. There are other low cost brands you will get replies to also.
04-06-2011, 05:50 PM   #3
slip's Avatar
I bought these a while ago and they seem to be really good. 55 dollars for a trigger and 2 receivers.
Phottix Tetra Wireless Flash Trigger with 2 Receivers
3 dollars shipping and was at my house within a week.
If you want P-TTL support you are likely looking at more bucks
good luck
cheers
04-07-2011, 05:37 AM   #4
hoanpham's Avatar
As for cheap ebay triggers, buy several as insurance to cover discontinuity.
04-07-2011, 02:50 PM   #5
bluebronco's Avatar
QuoteOriginally posted by imtheguy Quote
What flashes are you using with V5's? Can you use older manual flashes? I assume you can use nay brand of flash?
Thx
04-07-2011, 03:36 PM   #6
slip's Avatar
the cactus v5 does look like a good set, like the fact it is at 2.4G. guess mine will have to do
cheers
04-07-2011, 03:45 PM   #7
imtheguy's Avatar
QuoteOriginally posted by bluebronco Quote
Thx
AFAIK, anything works with the Cactus V5. They have high voltage filter built in so you can even use one on your camera just to safely use that old 250v flash from yesteryear. Because each unit is a transceiver, as the name implies, it can be transmitter or receiver. Botton side has both 1/4 20 thread and hotshoe so it fits on most anything except a 5/8" light stand stud directly. At this moment I have Metz 48, Pentax 360 and Vivitar 285 in the mix. I really like the Cactus so far but they are inexpensive and the build reflects that. Think opposite build of a k20d. At least the hot shoes are metal not plastic.
camera, ebay, pentax help, photography
Remote trigger vs onboard k-x wireless trigger irishwhite Photographic Technique 3 03-06-2011 04:36 AM
K20D/BG-2 and wireless trigger. Ed n Georgia Pentax Camera and Field Accessories 3 05-27-2010 12:42 PM
wireless slave trigger Nick SD Pentax Camera and Field Accessories 4 02-09-2010 06:18 AM
Wireless Trigger Problems remoteman Pentax Camera and Field Accessories 7 06-22-2009 01:49 PM
Troubles with wireless trigger on 540FGZ mparzuchowski Pentax Camera and Field Accessories 4 05-20-2009 10:16 PM
All times are GMT -7. The time now is 01:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
