04-05-2011, 06:15 PM   #1
White Dot on 50mm f1.4 Super-Tak
Hi,
What is the difference (if any) between a "normal" Super-Tak 50mm f1.4 and one with a white dot between 1.4 and 2 on the aperture ring? I have both of these and cannot find out any info. These are not SMC/Super Multi Coated...
Thanks,
Edd
04-06-2011, 03:21 AM   #2
Ira
From what I know, the only purpose of the white dot is to help you mount it in darkness on the body, which has a corresponding dot.
So maybe just different model years, but same lens.
04-06-2011, 04:42 AM   #3
selar's Avatar
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/52313-old-lens...white-dot.html
04-06-2011, 06:49 AM   #4
Hmmm,
I will take and post a photo (if I can) to show what I mean. It is not an alignment dot on the body. It is directly on the aperture ring, between f1.4 and f2.
Edd
04-06-2011, 07:31 AM   #5
boriscleto's Avatar
It marks the spot for f/2. The 8-element Super-Tak is marked f/2 but the 7-element Super-Tak has the white dot. The S-M-C and SMC went back to having a f/2.
04-06-2011, 07:45 AM   #6
GerryL's Avatar
If you take a look at our Pentax lens database, it would show you what to look for.
Heres the link for the 1st version and how to distinguish it: Super-Takumar 50mm F1.4 (Early 8-Element Variant) Reviews - Pentax Lens Reviews & Pentax Lens Database
Here's the 2nd version and how to distinguish it too: SMC/S-M-C/Super Takumar 50mm F1.4 Reviews - Pentax Lens Reviews & Pentax Lens Database
In any case the 1st version has a protruding/bulging back lens.
Hope that helps!
04-07-2011, 03:03 AM   #7
Boris and Gerry,
Thanks for replies...and the info on the data base. Got my answer now!
Regards,
Edd
07-20-2018, 01:47 PM   #8
premy2u's Avatar
an additional version
Actually, there are three versions of the Super Takumar 50mm f/1.4:
The first one has 8 elements, and has a "2".
The second one has 7 elements, and has a "2". Serial numbers: 2000000 to 2200000 approx. The feet scale appears white rather than light-blue.
The third one has 7 elements, and has a white dot. Its mechanism was updated to make usage of the Spotmatic F & ES's aperture enhancements.The feet scale is light-blue.
The other versions that followed, as we know, are the Super Multi Coated version and the SMC version (rubber contour).
50mm, 50mm f1.4, camera, dot, f1.4, pentax help, photography, super-tak
Super-Tak 50mm/1.4 versus Leica Summilux 50mm DanielT74 Pentax SLR Lens Discussion 47 01-19-2011 11:10 PM
Help ID my Super Tak 50mm 1.4 akfreak Pentax SLR Lens Discussion 58 01-03-2011 11:37 AM
Nature Another day with the 50mm 1.4 super tak. Yaro Post Your Photos! 2 07-29-2010 03:55 AM
$145 for a Super Tak 50mm 1.4!!!!!!?????????? Ira Pentax SLR Lens Discussion 45 04-17-2010 01:26 PM
All times are GMT -7. The time now is 03:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
