04-06-2011, 09:44 AM   #1
K1000: Problem with film advance
Hello everyone,
I'm having problems with a Pentax K1000 I bought on eBay and wondered if anyone had any suggestions.
After around 16 exposures, the film advance on the camera stops working. When you push the lever across, it feels 'unsmooth'. When the film is developed, the remaining images are on top of one another.
I left it at a repair shop but they quoted me over 100 Euros to fix it, which I did not proceed with. I'm waiting for them to confirm what the diagnosis was.
Has anyone had an similar experiences and knows of a cheaper fix? Or is it a case of paying for a repair or a new camera?
Thanks.
04-07-2011, 07:08 AM   #2
Banned
Sounds like the film was sticking in the canister. Does it feel "unsmooth" with no film loaded? If so. a repair is probably needed, if not, try a new roll of film from a different seller.
04-10-2011, 03:41 PM   #3
I've had a couple of films on mine that came out of the film "rails" as it slides behind the shutter and the film stuck on one of the corners, and as I pulled the lever (rather forcefully) the film ripped. Only happened twice.
04-11-2011, 02:42 AM   #4
Thanks - so you didn't do a fix, it just stopped happening?
04-12-2011, 06:14 PM   #5
I just figured I didn't put the film canister on correctly, as in it didn't seat all the way down. I guess I figured right in my case. It hasn't happened to me anymore.
04-13-2011, 01:44 AM   #6
Thanks - I tried again and managed two whole films through it yesterday which, hopefully, will come out ok.
04-13-2011, 07:32 PM   #7
Banned
QuoteOriginally posted by summernolan Quote
When you load your film, try to keep it as flat / tight as possible against the film rails, and be sure sprockets in front of the take - up spool are engaging the holes in the film before you close the cover. That should eliminate the slippage.
I'd also avoid that repair shop if I were you, sounds like they were ready to charge you for work that you didn't need, and likely wouldn't have been done.
04-14-2011, 12:39 AM   #8
Thanks for the advice. I'm very glad I didn't pay for that repair!
advance, camera, film, k1000, pentax help, repair
Pentax K1000 film won't advance summernolan Troubleshooting and Beginner Help 2 03-04-2011 12:50 AM
K1000 mirror locks up with film advance awsutter Pentax Film SLR Discussion 4 12-27-2010 12:34 PM
ZX-L film advance problem clawhammer Pentax Film SLR Discussion 5 08-16-2008 08:54 PM
Super Program problem with film advance and shutter release Laurie60014 Pentax Film SLR Discussion 6 07-18-2008 09:00 PM
ME Super film advance lever problem! Thursday Pentax Film SLR Discussion 8 09-12-2007 12:07 AM
All times are GMT -7. The time now is 11:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
