04-08-2011, 05:22 AM   #1
Pentax K100D Super with Sigma 28-200mm lens - Not working?
Hi, I just received my Sigma lens through the post today, which I got on ebay.
Its a Sigma 28-200mm lens, which was advertised as compatable with all Pentax film and digital cams with K/KA mounts, including my K100D. I put it on my camera, and it just comes up with a flashing Av bit on the top, and won't let me take any photos or adjust any of the values - It just flashes the Av- - symbol at me, mocking me
Its just so annoying considering it'll take photos without a lens attached or with my 18-55, but, with my 28-200 sigma, it doesn't do anything at all.
I noticed this... The connectors on my camera are like this...
But, the connectors on the lens are like this...
Although, I then noticed the ones on the 18-55 are even more different...
Any idea how to sort this? I don't really wanna send it back, as if it works, that lens will do everything I wanted.
Cheers,
Jamie
04-08-2011, 07:45 AM   #2
paulh's Avatar
I'm no expert, but I'd try cleaning the contacts on the lens and the camera with a bit of naptha (lighter fluid) or alcohol. (I think these would be safe to use, anyone feel free to correct me.) It seems the lens isn't communicating with the body, that's why I suspect the contacts may be dirty. Also, if the lens has an aperture ring, make sure it's set to the 'A' position. Good luck.
04-08-2011, 08:57 AM   #3
What does setting it to the A position on the aperture ring do? After some more searching of my problem, I found an answer on this forum - Turns out I had to enable aperture rings, or something - Which I did, and it is now working! So, that's something!
Sorry I didn't search harder initially, and thanks for the answer!
Took this from a faaaiiiir way away, zoomed in about 180mm
So, I'm happy! Finally got a new lens.
04-08-2011, 09:35 AM   #4
paulh's Avatar
QuoteOriginally posted by JSM Graphics Quote
Setting the lens aperture ring to 'A' allows the lens to communicate with the body - so you can set the aperture using the command wheels on your camera. On older manual lenses you would set aperture using the ring on the lens itself. Some newer lenses like your Sigma allow this also. Glad to hear you're up & running
28-200mm, camera, connectors, k100d, lens, pentax help, pentax k100d, photos, sigma
For Sale - Sold: Pentax K100D Super with upgraded Pentax DA 18-55mm f/3.5-5.6 AL II lens + SMC ravinj Sold Items 6 05-27-2010 06:50 PM
Sigma EF-500 DG super for Nikon on a Pentax K100D? Nathan-vD Pentax Camera and Field Accessories 4 09-04-2009 07:18 PM
For Sale - Sold: K100D Super w/NEW Pentax 18-55mm AL II Lens jays0n Sold Items 10 08-13-2009 12:05 PM
For Sale - Sold: Pentax K100D Super body and lens, new in box tomwil Sold Items 2 06-04-2009 06:38 AM
Pentax K100D Super + 18-55mm kit lens or Penatx K200D + Sigma 24-60mm f/2.8 Thareen Pentax DSLR Discussion 10 08-25-2008 08:52 AM
All times are GMT -7. The time now is 08:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
