04-08-2011, 07:21 AM   #1
Focal length with a teleconverter
Just checking. If I am using a 2x teleconverter with a 50mm A lens, it asks for focal length. I would input 100 at this point, correct?
Thank you
04-08-2011, 07:55 AM   #2
imtheguy's Avatar
Yes, 100mm.
04-08-2011, 08:07 AM   #3
itg is correct. Here's how it works. Shake reduction is different depending on focal length, there is more correction the longer the focal length. Since you have 50mm lens and a 2X TC, you are essentially working with a 100mm lens, and you will need SR to match. If you were using a 1.4 TC you would dial in 70, and if you are lucky enough to own the Pentax 1.7 TC you would dial in 85.
NaCl(hope that helps)H2O
camera, length, pentax help, photography, teleconverter
focal length pentax k-x Photographic Technique 9 11-22-2010 12:41 PM
focal length ewig Troubleshooting and Beginner Help 11 07-23-2010 09:32 PM
focal length landscaped1 Troubleshooting and Beginner Help 48 05-05-2010 03:04 PM
K7 is 1.5 x focal length? rdrum76 Pentax DSLR Discussion 18 06-30-2009 08:30 AM
Teleconverter & Focal length Bart Troubleshooting and Beginner Help 7 04-18-2009 12:37 PM
All times are GMT -7. The time now is 03:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
