04-09-2011, 11:30 PM   #1
Can't turn shake reduction back on - K5
Hoping that this is a simple oversight. I've been using my K5 with shake reduction on, in P mode, the hand is there. Then today I put my K5 with DA 15 on a tripod and turned off Shake Reduction by following the instructions in the manual. No problems, the hand now has a "not" symbol. I took some shots. Then I switched the camera off, took it off the tripod, switched back on, followed the instructions in the manual to turn Shake Reduction back on.
BUT .... I can select the "on" symbol, but pressing "OK" results in the "not on" symbol remaining selected
OK, the manual says that there are various causes for no Shake Reduction, but as far as I know, I haven't changed any other settings
I have searched this Forum for a similar problem, but can't find an answer, hence the new thread.
Oh, and I'm so new to Pentax that I need to read the manual nearly every time that I want to change a setting - it took me a few minutes to work out that menus are greyed out unless the camera is not in Auto/Green mode, but I was able to work that one for myself.
Am I missing something obvious again? What is it?
Thanks in advance
04-10-2011, 12:07 AM   #2
Take the camera off self-timer mode
04-10-2011, 12:36 AM   #3
Ahem (feels a mite foolish) .... how do you turn self-timer off (the manual only tells me how to turn it on) ?
04-10-2011, 12:48 AM   #4
QuoteOriginally posted by vrphoto Quote
Select a different drive mode. Push the button directly above the OK button, and scroll to the green rectangle on the left (single frame shooting). Then press OK.
04-10-2011, 02:38 AM   #5
(looks like this thread should be moved to the Beginner's Corner) -
Yes, pushed the Drive mode button, selected Single Frame Shooting, pressed OK. Went back to the Menu etc, etc to change the Shake Reduction setting. Still won't change to On after selection/OK combination (emoticon for Grrrrr = ?)
Any other ideas, anyone?
At least the practice is making me faster at working the menus
And I'm grateful for the help
04-10-2011, 09:22 PM   #6
Definitely to the Beginner's Corner - problem sorted. If any other newbie wants to know about this, just ask and I'll provide the half page explanation (faster to show than explain)
camera, hand, instructions, k5, mode, pentax help, reduction, shake, shake reduction, symbol, tripod
Shake Reduction won't turn on.. ChallengedOne Troubleshooting and Beginner Help 12 04-11-2011 01:18 PM
Shake Reduction wont turn on in video jupzchris Pentax DSLR Discussion 2 06-13-2010 09:43 PM
Why Turn Shake Reduction Off? slowdive101 Pentax DSLR Discussion 36 02-14-2010 07:03 AM
When to Turn on Noise Reduction? cbaytan Pentax DSLR Discussion 18 05-21-2009 11:14 PM
Shake reduction julianactive Pentax SLR Lens Discussion 2 05-06-2009 04:13 PM
All times are GMT -7. The time now is 08:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
