Originally posted by yanzhi0714 Hello, I am interested in knowing how to manual focus properly. I am using a K-r
I currently wear specs for short sightedness (around -2 to -2.5). I found that through the viewfinder, with the diopter slider all the way to the right, I have the same "view" with/without the glasses.
At this diopter setting, I find that I need to have both eyes open (one through the viewfinder, one looking straight ahead outside of viewfinder), to be able to get the sharpest (still not sharp enough in my opinion) possible info bar and the boxes in the viewfinder.
I might be totally wrong on how to see through a viewfinder. Do I wear my specs or specs off? Please do correct me. Thank you.
I usually take my glasses off and use my left eye through the viewfinder cause I'm basically blind in my right eye and I don't use a Katz eye etc but rely pretty much on the camera indicators, so far so good...
It just takes tons and tons of practice to get manual focusing just right
plus knowing your camera and different lenses. I personally focus from the infinity end, I've found this is the most accurate. Lots of sharp fast lenses will lag a little before the camera indicator finally kicks in (due to depth of field etc), so when you can see your getting close, slow down and give the camera a chance. Go back and forth, till your pretty sure...
I practice on a newspaper, making sure I point the camera to a specific word, take a shot, and take a quick look. You might find you had the camera pointed at a slightly different location than you intended, etc. so just practice practice practice.
Good luck...
