Originally posted by lovemehate these have no editing
messed with the white balance stuff a bit (Need help when knowing when to do this)
You do realize it looks from the EXIF info that all of your photos were done in Manual Mode and the lens aperture wide open? I would switch to Av (Aperture Priority), stop down to f6.3-8 and use Auto white Balance to start with...
Originally posted by lovemehate Lighting, ligthing, lighting... from your samples it looks like your actually shooting into the sun or pretty close to it. You should shoot with the sun to your back which should help with better contrast and color. Most photograhpers know a bright cloudy day is the best time to take photos, midday sun light tends to be harsh and washes out colors.
and with the Kit Lens, you should be able to get within a foot or so of your subject at 55mm, so you need to get down closer. You might also, want to change meter to center weighted instead of matrix...
As per Software, consider Picasa, it's free and all you need is to push a button here or there and it will improve your photo. When you master Picasa, you can move up to Faststone, also free and with a few extra bells and whistles...
Kit Lens, f6.3, Sun behind and above my left shoulder. PP using Faststone...
Details
