04-16-2011, 11:51 PM   #1
Meanfiddler's Avatar
Is Kx Firmware update neccesary?
Howdy folks! I'm new to the forum and a new K-x owner. It came from B&H with 1.0 firmware and I'm happy with it so far, although I've still a lot to learn. The images seem fine and the battery meter seems to work with both Enloops and lithium batteries. I think SDHC cards are fine for me right now as I'm still learning. Will updating the firmware improve the performance considerably, or should I leave it alone?
A clumsy question perhaps... thanks for your time.
04-17-2011, 12:48 AM   #2
There are only two new features (cross-processing options and SDXC support), so unless you need those, the update won't do you much for you. I can't hurt, though- there's no real risk or anything.
04-17-2011, 01:35 AM   #3
KxBlaze's Avatar
I know the OP said his battery meter was working fine but the update also fixes/makes the meter more accurate also. Your Kx might start to show faulty battery readings later on, this update will prevent that from happening. But to answer your question you will not notice a performance increase so the update is really up to you. It only takes a few minutes so my suggestion is to do it.
04-17-2011, 01:46 AM   #4
I have the latest firmware on K-x and battery meter is still working like crap.
04-17-2011, 01:49 AM   #5
aurele's Avatar
maybe you have set it right ... or your are using crappy batteries :P
04-17-2011, 11:16 PM   #6
Thanks y'all. I'll try the update and let you know how it goes.
04-18-2011, 09:39 AM   #7
QuoteOriginally posted by aurele Quote
I use 2 sets of eneloops...i keep both charged never did a count on how many photos / set charged, but i don't think is more than 4-500 at best. The battery meter goes to yellow (half) after max. 50 photos. Don't use a lot of flash or review pictures.
04-18-2011, 04:54 PM   #8
JHD
Ignore the meter and keep 4 back ups on hand. With Eneloops you should be getting around 500 shots per charge - that is assuming you're not using the flash and LV.
04-18-2011, 05:32 PM   #9
DaveHolmes's Avatar
QuoteOriginally posted by JHD Quote
I get more like 800 out of my Eneloops... But agree, even with the firmware update (which does improve things) just run til they die and then chuck your spares in...
04-18-2011, 05:41 PM   #10
Eruditass's Avatar
It is a bit annoying when shooting events since it gets to red fairly early. I went through a couple sets of backup batteries, not wanting to run out of battery during a critical moment, before reluctantly going back to the original, which ended up lasting in red much longer than expected.
camera, firmware, kx firmware, pentax help, photography
KX FIRMWARE UPDATE ANVILHEAD911 Pentax DSLR Discussion 9 12-12-2014 08:41 AM
K-7 Firmware Update-Help gilbej49 Pentax DSLR Discussion 22 01-13-2011 10:57 AM
KX firmware update kparkypark Troubleshooting and Beginner Help 10 04-28-2010 08:38 AM
KX FIRMWARE UPDATE ntarbox Troubleshooting and Beginner Help 3 01-21-2010 04:18 AM
K7 Firmware Update Workingdog Pentax DSLR Discussion 2 12-22-2009 01:53 PM
All times are GMT -7. The time now is 02:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
