04-18-2011, 02:03 AM   #1
kooks's Avatar
External Flash ... Off???
Hi. I just got my Pentax K-r 2 days ago so im still learning the functions and all that... so i have a really basic question.. I used to own a LUmix camera and when i was using an external Flash i had the possibility to force the external flash not to trigger without turn it it off... now.. in my K-r .. if i press the flash button and the flash options pop up.. i cant see how to turn the flash off with out turning the flash off manually....
Is there a way to dont trigger the external flash from the camera??? or it is necessary all the time to switch the flash off if i dont want it to trigger??
Cheers and sorry about the confussion.. :P :P
04-18-2011, 05:36 AM   #2
mtansley's Avatar
Hi,
I believe (and I could be wrong, others please feel free to correct me) that most if not all DSLRs are designed to send a signal to the external flash unless the lighting conditions don't require it and the camera is set on a very automatic mode to make it more like a Point & Shoot.
I generally assume that if the external flash is connected and I don't want to use it then I either turn the flash off or unplug the sync cable from the hotshoe if my flash is connected off-camera.
I know the my K20d won't automatically pop up the built in flash under ANY conditions but my Nikon D80 WILL pop-up the built in unit if I have it set to an automatic mode.
Michael
04-30-2011, 06:41 AM   #3
Flash off on mode dial
Not sure if this will work for you.
There is a "Flash off" setting on the Mode Dial. It sets the camera to AutoPict Standard mode with the flash off. I've never used that setting.
I looked for that function in the menus also, but turning off the flash itself is easy. It's a dedicated button on the flash vs a menu. Same with the pop up flash. When it's down, it's off.
dont, flash, k-r, pentax help
Do you use an external flash? rustynail925 Flashes, Lighting, and Studio 23 02-28-2010 07:21 AM
need help with my external flash Death2man Flashes, Lighting, and Studio 2 01-17-2010 01:17 AM
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
external flash with k-x grakenverb Pentax DSLR Discussion 3 12-25-2009 05:25 PM
Best external flash for the k-7 alman Flashes, Lighting, and Studio 9 07-23-2009 02:54 AM
All times are GMT -7. The time now is 12:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
