Hi I am having problems with the autofocus of a 3 y.o. Pentax K20D + Tamron 18-250 Superzoom. Problems have begun in the past 3 weeks, and are becoming worse with time. Previous to this the camera + lens has been problem free.
At long focal lengths the camera will not autofocus at all, in bright sunlight and regardless of the object, whereas it autofocuses straight away on the same objects at short to medium local lengths under the same lighting conditions. In fact the autofocus hunting problem seems to be similar to that which some cameras have in very low-light conditions, but is occurring for images taken in the middle of the day, under bright sunny conditions. When this AF problem occurs the camera seems to be choosing very slow shutter speeds (in green and other modes) for such bright conditions The same problem occurs in normal and continuous AF mode. I not am unsure if this is a lens (currently don't have access to another lens to check) or a camera (AF motor?) issue, but would be grateful for any suggestions.
regards,
Ian
