04-24-2011, 02:32 AM   #1
sany's Avatar
Hood & Filter
I am having Pentax-DA 35mm F2.4 AL with 49mm for the filter, now my question is, if I fix a polarizing filter since the thread in the lens is occupied by the filter - how the hood can be fixed or is there a different way to fix the hood to lens. Sorry I have not seen or used a filter or a hood. Pls advice.
04-24-2011, 09:41 AM   #2
RioRico's Avatar
If it is a screw-in lens hood, just screw it into the filter. If you see vignetting (dimming at the corners of the image) then you need a wider hood.
04-24-2011, 09:47 AM   #3
HEEGZ's Avatar
You screw the 49mm filter into the lens, and then thread a 49mm hood onto the filter. I would take a picture of my setup but apparently my second camera is in the car with my wife out of town at the moment.
04-24-2011, 11:08 AM   #4
sany's Avatar
Thanks that makes the 'how it works' clear for me. Also RioRico's comment on vignetting makes me nervous - isn't there anything clear cut as it sounds like a trial and error method.
04-24-2011, 12:50 PM - 1 Like   #5
RioRico's Avatar
QuoteOriginally posted by sany Quote
Not trial and error, but some test shots. Take a picture of a clear blank white wall. Chimp it -- review it on the LCD screen. Zoom in a few steps. Scroll to the corners of the picture. If they look dark, you have some vignetting. Take off the hood and repeat. If you see the same amount of vignetting, it is not the fault of the hood.
04-24-2011, 03:09 PM   #6
HEEGZ's Avatar
Do you already own the lens hood or are you going to buy one?
04-24-2011, 07:24 PM   #7
Not having a dedicated hood mount is a pretty gross design defect for any lens. It's very disappointing if that's the case with this lens.
Paul
04-25-2011, 03:31 AM   #8
RioRico's Avatar
Umm, most lenses DO have hood mounts. They're called front threads.
04-25-2011, 04:55 PM   #9
A front filter thread is a poor mount for a lens hood. My 100-300mm Pentax suffers from this design limitation, but I bought it (used) knowing this. So it may not be a fatal limitation, but it's a limitation. My other lenses have better hood mounting mechanisms.
Paul
camera, filter, hood, lens, pentax help, photography
FA 43mm filter & hood rpark71 Pentax SLR Lens Discussion 60 04-17-2011 04:18 AM
Filter & hood size - 77mm, 72mm, or less? Kitty Troubleshooting and Beginner Help 24 01-22-2011 08:15 AM
For Sale - Sold: Pentax smc A 20mm f2.8 + original case box filter & Hood (Worldwide) Fleafly Sold Items 5 07-05-2010 01:53 PM
Lens hood with filter window AndyB Pentax Camera and Field Accessories 10 04-11-2010 02:58 AM
Do I need a lens hood and a filter for K2000 Agesconde Troubleshooting and Beginner Help 25 06-07-2009 10:27 PM
All times are GMT -7. The time now is 09:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
