I posted this issue in the K5 forum, but thought it might be more appropriate to put it in here as well.
I got my K5 yesterday but am wondering if I should take it back as it makes a weird sensor "flopping" when I put it into live mode. It doesn't seem to do this when put into movie mode interestingly enough, and only seems to do it when LV is first turned on. When the camera is moved around is slows down and stops. Sometimes it doesn't happen at all if LV is turned off and back on, but turning the power off reproduces the situation 75% of the time.
I tried a search and saw no posts on this and wondering is this a unusual issue, or is it normal and just need to the sensor to adjust to movement before being ok for LV. I've never seen this son my K7, which I used to record it.
It's always jittering on the left side of the lcd, not sure if that would be the right side of the sensor depending how the image is flipped onto the sensor going threw the lens.
the video uploaded here:
