04-25-2011, 07:27 PM   #1
Kx ISO extended range
Hey! Good evening to you all! It seems my Kx has lost the lower part of the extended range. I don't know how that happened. But I've tried reseting to factory settings and still the lowest it goes is 200. Anyone had this problem? It seemed to have happened right after installind the firmware update. Was that supposed to happen?
04-25-2011, 07:42 PM   #2
- Turn off D-range settings (Highlight/Shadow correction)
- Custom Setting 3. Set Expanded Sensitivity to On (2)
04-25-2011, 07:42 PM   #3
jremick's Avatar
Is it enabled in the menu? It's on Tab 4 -> page 1 -> option 3 -> select #2
04-25-2011, 07:45 PM   #4
haha that was such an easy fix! thank you jellyfish! My highlight correction was left on.
04-26-2011, 03:52 AM   #5
Elva's Avatar
Location: Grahamstown in the Eastern Cape province of South Africa
LOL I had the same thing happen then I did this and all was back to mornal
kx, pentax help, range
Does setting the ISO/sensitivity range work in Movie Mode? BrianStanding Video and Pentax HDSLRs 8 03-13-2012 09:19 AM
K-x extended ISO P12 Pentax DSLR Discussion 5 10-29-2010 01:48 AM
Is it time for the ISO range to retire? bymy141 Photographic Technique 18 10-27-2010 10:17 AM
K-x extended ISO range alphalt Pentax DSLR Discussion 9 05-03-2010 10:30 AM
ISO range in TAv mode? (K20d) Ratmagiclady Pentax DSLR Discussion 4 12-11-2009 12:06 PM
All times are GMT -7. The time now is 12:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
