04-27-2011, 04:02 AM   #1
Pentax 55-300 vs 55-200
Hey All,
I've narrowed down the search for my first telephoto to these two lenses. I would love to know the consensus on these, if ya don't mind. Also, what affordable additions might be useful for macro? My kx dSLR came with a 18-55--would I still need a macro addition?
Thanks,
Malcolm
04-27-2011, 04:13 AM   #2
sterretje's Avatar
55-300 is, by most people, considered the better lens.
If macro equals close up of flowers etc, your 18-55mm kit lens will be fine (1:3 magnification). If you need better than that, have a look at the Raynox DCR150 adaptor to keep it affordable.
And next you can get to dedicated macro lenses (often 1:1 magnification), tubes, bellows etc. Somebody else might climb in here as my knowledge is limited.
04-27-2011, 07:08 AM   #3
JHD
While it is true that the 55-300 is a "some what" sharper lens - the 50-200 is much lighter and smaller - and it can also boast weather sealing. I ditched my 55-300 in favor of the 50-200 WR for those reasons.
If you want long lens with great IQ, you need bigger budget. Even though the Tamron 70-200 has been critically acclaimed as the undisputed value king, it will set you back more than $700, but it is about as sharp as anything made by anyone regardless of price within its focal length.
04-27-2011, 07:26 AM   #4
Thank you! Is the extra 100mm a huge loss? I'm new to photography and am not exactly sure how to measure this.
04-27-2011, 07:28 AM   #5
Ash
Community Manager
Ash's Avatar
For image quality the 55-300 is definitely the more superior lens. It can be used wide open and produce sharp images, even at 300mm, which is rare for a consumer telephoto.
Value for money, size and IQ, you shouldn't go past it.
For these reasons I have one even though I also have a Tamron 70-200.
04-27-2011, 08:48 AM   #6
sterretje's Avatar
The difference is quite big.
Suppose you're on a safari and with 300mm you can have an elephant fill the frame (photo). With 200mm, it will only fill 66% (300/200). This is not a big issue, as the composition will usually be better if you show a little of the environment around the elephant.
However, if that elephant is further away, it might only fill 50% of the photo with a 300mm lens and only 33% with a 200mm. And in that situation it makes a bigger difference. If course you can try to get closer.
Attached a photo of a weaver taken with 300mm and at a few meters distance; no cropping With 200mm the bird would have been smaller (66% of the size) and you would have seen more of its environment. For this one, I could not get much closer. You can obviously always do a bit of cropping but cutting 33% away is quite significant in my opinion.
PENTAX K10D  Photo
04-27-2011, 08:58 AM   #7
QuoteOriginally posted by creigm Quote
You can shoot at 200mm using the 55-300 but you can't shoot at 300mm with the 50-200. Something to think about.
Tim
04-27-2011, 07:13 PM   #8
Ash
Community Manager
Ash's Avatar
And at 300mm, the quality is excellent - even wide open!
A couple of cases in point:
camera, macro, pentax help, photography
Which TC for the highest quality on DA*200, DA*300 and/or FA*300 stl09 Pentax SLR Lens Discussion 22 02-15-2011 10:23 PM
For Sale - Sold: DA* 16-50mm/2.8, 50-135/2.8, 200/2.8, 300/4, DA 12-24/4, 18-50, 50-200, K10D Albert Siegel Sold Items 15 08-14-2010 08:51 AM
cheap vacation zoom: 18-200, 28-200, and 28-300 Eruditass Pentax SLR Lens Discussion 23 10-07-2009 05:45 PM
I've read the reviews - still need help -DA 50-200, FA 75-300, DA 55-300 Neisey Pentax SLR Lens Discussion 7 08-22-2009 08:43 AM
Pentax 50-200 vs. Sigma 28-200 (vs. Tamron 70-300) shefaet Pentax SLR Lens Discussion 7 11-24-2007 10:44 PM
All times are GMT -7. The time now is 01:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
