04-27-2011, 06:01 PM   #1
Trying to find a lense
Hello. I got a ist DS from my dad when he passed away. I dont know much about this camera as far as what the lense numbers mean and things like that. I was wondering if some on could suggest a lense that I could use to zoom in on things, like far shots of animals at the zoo, that is not expensive. I have a 1:2.8 100mm lense but its not cutting it.
Any suggestions would be great.
Thank you,
Jason
04-27-2011, 06:09 PM   #2
joe.penn's Avatar
I have been testing a Tamron 28~200mm XR IF, and it seems pretty good - good sharpness, good contrast, good overall image quality, it is auto-focus and it is a good range with the 28~200. You can get it new somewhere around 250-300...
04-27-2011, 06:14 PM   #3
OK.. Another thing... I dont understand the numbers. Like the 28~100mm. Sorry..
04-27-2011, 06:24 PM   #4
hcc
hcc's Avatar
QuoteOriginally posted by MajorIssues Quote
This means that the lens is a zoom lens with a focal length range between 28mm and 100mm. (or about 3.6 optical zoom).
Your current lens is a 100mm f2.8 (1:2.8). That is, your lens corresponds to the upper end of the zoom lens 28-100mm. The lower end (28 mm) is a much wider focal length (ie you will see a wider picture).
04-27-2011, 06:29 PM   #5
So the higher the number the longer the range?
04-27-2011, 06:43 PM   #6
audiobomber's Avatar
The budget choice I'd recommend is the Tamron 70-300 LD Di (in Pentax mount). The step up from this would be the Pentax DA 55-300mm. Here are my zoo photos with the Pentax (the flamingoes lion tamarin and spider monkeys were shot with the FA 50mm 1.4) https://picasaweb.google.com/bonhommed/TorontoZoo#
04-27-2011, 06:50 PM   #7
hcc
hcc's Avatar
For a 28-100 mm zoom, the range is between 28 and 100mm. The longest end 100mm is the maximum zoom. The smallest end (28mm) is the widest angle.
camera, lense, pentax help, photography
Which Lense Next ? Frogfish Pentax SLR Lens Discussion 7 04-17-2011 10:18 PM
lense sunnybrooke Troubleshooting and Beginner Help 6 11-01-2010 02:47 AM
I really need to find... Aperturae Photographic Technique 6 12-18-2009 08:06 PM
Which Lense for the K-7 SimoneDice Pentax DSLR Discussion 15 09-26-2009 03:44 AM
Noob Question Difference Between a Lense That Does Macro & A True Macro Lense Christopher M.W.T Troubleshooting and Beginner Help 16 07-19-2009 12:20 AM
All times are GMT -7. The time now is 02:38 AM. | See also: NikonForums.com, part of our network of photo forums!
