04-29-2011, 01:55 AM   #1
Aperture adjustment and k-x
Okay, so Im a bit confused. I picked up a pentax 50mm/1.4 lens and am trying to get it working on my camera. So, I have set the aperture ring setting to permitted, have the camera in M on the dial, and the manual on the focusing. All good, but if I turn the aperture ring, I cant see the blades move at all...all is good when not on the camera and the blades move perfectly when turning the rig, but when I put it on the camera the blades open to the 1.4 setting...
Is this what is meant to happen?
04-29-2011, 02:10 AM   #2
aurele's Avatar
QuoteOriginally posted by goldpopper Quote
YES !
You always "aim" at full aperture, whatever the lense you use.
When you shoot, blades will move to the aperture set.
You can set the "green button" (menu, number 4 on the right / "green button" / optical viewfinder (?)* ) then, when you put on "M mode", when you'll press the green button, it will stop down your lense from full aperture to what you choose.
If the viewfinder* get a bit darker, it's all good !
Note : when you'll press the green button, then blade will move to aperture you want, so DOF will be bigger, and the focusing easier, if there is enough light.
*i'm french (so i used a translator for this word, don't know if they are right ones )
04-29-2011, 02:34 AM   #3
Aaah, get it now. Obviously have a fair bit to learn still . Got it working and viewed the blades close up , and have the optical preview sorted. Looks good. I am glad that I have a DA40mm as well, as focus is bit harder and takes longer manually. But should prove to be a great lens to play around with. Many thanks...
aperture, blades, camera, move, pentax help, photography
Constant Aperture vs Variable Aperture Netsoft Pentax SLR Lens Discussion 13 01-11-2010 07:29 AM
AF Adjustment cupic Pentax DSLR Discussion 8 08-12-2009 09:30 AM
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
No AF- adjustment in K7 ? lock2nl Pentax News and Rumors 6 05-20-2009 04:03 AM
ID'ing weather-sealed lenses; aperture adjustment question amateur6 Pentax SLR Lens Discussion 10 03-18-2007 06:46 AM
All times are GMT -7. The time now is 12:34 AM. | See also: NikonForums.com, part of our network of photo forums!
