05-01-2011, 06:39 PM   #1
Spot in photos using 300MM zooms
The attached photo of a hawk was taken with a s Sigma 75-300mm. You can see a spot near the top quarter of the frame, as well as two small ones in the lower portion. I had similar spots when using a Pentax 100-300mm and thought it was the Pentax lens, but now I see it with the Sigma as well WHEN set at 300mm or somewhere in that range. Photo was taken with a K-10.
Can someone tell me the cause of this>
05-01-2011, 06:44 PM   #2
wwwmorrell's Avatar
Dust on your sensor.
05-01-2011, 07:01 PM   #3
SpecialK's Avatar
At least 5 spots. A Giotto rocket blower is essential.
05-01-2011, 07:16 PM   #4
It's dirt on the sensor..
https://www.pentaxforums.com/forums/pentax-dslr-camera-articles/121739-those-...ml#post1259109
Your lens would have to be VERY cruddy for it to show up in a photo.
05-01-2011, 11:25 PM   #5
Bramela's Avatar
Blower is what you need. but DO NOT touch the sensor with a cloth etc. Scratches, which will be very tiny on the sensor would show up as huge on a photo. Can ruin your camera.
05-02-2011, 04:42 AM   #6
I have found with my K10D that simply blowing isn't always enough to remove the dust. The K10D seems to be worse than other models in this regard.
Step one is always as others have said, simply blowing out the box, then opening the mirror and blowing out the sensor area (with the camera pointed down.
Then take a picture of a clear evenly lit empty sky using a small aperture and inspect the resulting picture for spots.
Step two (I need to do this about 3/4 of the time when I clean) is to dab clean the sensor using something like the "Pentax Lollipop" (mine is sold by Dot Line Corp and appears identical).
Then take a test picture again.
If needed (I haven't yet) the third step is a wet cleaning or professional cleaning.
In any and all cases, be very careful not to scratch the sensor's filter.
05-02-2011, 01:27 PM   #7
It isn't the lens...
05-02-2011, 03:28 PM   #8
Ex Finn.'s Avatar
QuoteOriginally posted by mobygrape Quote
Nope.
05-02-2011, 05:50 PM   #9
Thanks
300mm, pentax, pentax help, photo, sigma, spot
For Sale - Sold: DA 40mm and fine AF zooms: DA 55-300mm, Tamron 70-200mm/2.8, 28-75mm/2.8, Sig farfisa Sold Items 20 07-25-2010 02:36 PM
For Sale - Sold: Exceptional zooms - Tamron 17-35mm di and Sigma 70-300mm apo di tundraguide Sold Items 5 07-17-2010 05:04 PM
Soft spot in photos? Humidity? Settings bugsy603 Photographic Technique 9 06-14-2010 06:52 PM
Zooms ending in 250-300mm range Laurentiu Cristofor Pentax SLR Lens Discussion 22 06-13-2010 02:32 PM
brown spot on photos annod Pentax SLR Lens Discussion 6 10-05-2009 10:22 PM
All times are GMT -7. The time now is 01:48 AM. | See also: NikonForums.com, part of our network of photo forums!
