05-14-2011, 12:28 AM   #16
pop4's Avatar
Most of the above posts seem to be focusing on screw-in filters, e.g. circular filters that screw into the front filter thread of a lens, but don't forget, there are also other types of filters, ones that are part of a filter system, e.g. Cokin or Lee filters. The filters themselves are square, and fit into filter holders that mount on an adapter screwed into the front of a lens. I use the Cokin filter system, and have found GND filters and to some extent, ND filters, pretty much essential when I'm shooting sunrise/sunsets.
05-14-2011, 03:31 AM   #17
Senior Moderator
Nass's Avatar
Yes there's a place for filters although many filter effects can be approximated in post processing. Personally I've just forked out 400 on Lee stuff and am eyeing a further 300 worth of actual filters. Top filters are expensive but once you've got them you'll never need them again.
05-14-2011, 06:18 AM   #18
reeftool's Avatar
QuoteOriginally posted by Nass Quote
Yep, filters have their place and always will. Many of us, myself included, always put a skylight or UV filter on our lenses from day one because that was the accepted practice. Usually it came from the sales staff that the filter was needed so we bought them. No, you don't need a permanent filter of some sort on the front of your lens unless you are always shooting in an environment where your lens needs some protection. Other filters such as CPL's, neutral density, and scores of other specialty filters will always have their uses. Yes, you probably can reproduce the effects in PP but it will be time consuming and I would much rather spend my time behind my camera than in front of a computer screen.
camera, filter, pentax help, photography
Any idea on what kind of filter this is? (Soviet made) smrk Pentax SLR Lens Discussion 3 03-12-2011 09:50 PM
Lens Correction: Good or Bad Idea? bigdave56 Pentax DSLR Discussion 20 10-31-2010 03:58 PM
Bringing the K-x along for a jog.. good idea? hagiri_11 Troubleshooting and Beginner Help 7 10-07-2010 06:42 PM
Rebuilding the Infrastructure - A Good Idea? seacapt General Talk 47 09-15-2010 07:56 AM
Thinking of buying a Pentax 14 mm F 2.8-good idea? lesmore49 Pentax SLR Lens Discussion 39 04-20-2010 10:15 PM
All times are GMT -7. The time now is 10:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
