05-07-2011, 10:15 AM   #1
K-x Burst Rate with Different Lens
How do I drive up the burst rate with my K-x. When I use my old manual focus 300mm (Tamaron adaptall) I can take up to 10 to 20 pictures before the camera needs to pause. But my DA10-17mm or 18-55mm I can only take two or three. It's the same for my Tamron 18-250mm I get maybe two or three pictures. When I use my FA50mm1.7 I can get up to five pictures.
I am using the same settings. Most of my pictures are indoors in a theater.
05-07-2011, 10:36 AM   #2
Check that Lens Correction and D-range Settings are turned off.
05-07-2011, 10:46 AM   #3
philbaum's Avatar
If each shot is of the same subject area, focus once and shoot many times. Making the camera focus for each shot in a burst is very time consuming.
Enable AF button shooting, disable half press shutter focusing.
best wishes,
05-07-2011, 03:10 PM   #4
hcc
hcc's Avatar
QuoteOriginally posted by jellyfish26 Quote
+1
You must switch off all in-camera processing incl. lens correction, High-ISO correction, .....
Ensure that you have a fast card. The k-x buffer memory is smaller compared to the K-7/K-7 buffer, and the camera rate will drop as soon as the buffer is full.
burst, camera, k-x, pentax help, photography, pictures, rate
How AE affects burst rate? syoon1970 Pentax K-5 5 01-07-2011 01:57 AM
How good would you rate this lens? knyghtfall Pentax SLR Lens Discussion 9 11-02-2010 04:16 PM
Misc Did you know you can rate each picture pcarfan Post Your Photos! 7 06-18-2010 08:12 AM
Misc Rate the photo above yours kevinschoenmakers Photo Critique 15 05-27-2010 12:35 AM
K2 Going Rate? deadwolfbones Pentax Film SLR Discussion 10 07-16-2009 07:47 PM
All times are GMT -7. The time now is 08:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
