05-08-2011, 04:42 PM   #1
AF/MF switch
HI,
I was gifted a Pentax K10D, by a good friend who told me there was a problem with the Auto focus. When I switch the MF/AF switch to AF, the camera still says MF in view screen. I do not want to think I have to send it in to get repaired, as I can not really afford that, and I wanted to know is there some sort of repair I could do on my own. I still can take pictures in MF, but I would really like to have auto-focus with my camera.
Thanx
05-08-2011, 05:11 PM   #2
Check the following 5 things:
-is the lens an SDM lens? If so, make sure you have firmware 1.30 isntalled
-is the AF/MF switch on the lens (if any) set to AF?
-is the lens properly mounted?
-does the problem occur with more than 1 lens?
-have you cleaned the lens contacts?
05-08-2011, 05:37 PM   #3
Of course the most obvious question is, Is the lens an Auto focus lens? Or is it a Manual focus lens?
If the lens is an SDM and has the screw drive as well (16-50 and 50-135) it should auto focus even without a firmware update and in fact, you may want to leave it that way to keep SDM disabled.
05-08-2011, 07:05 PM   #4
I have 2 lenses SMC-DA 18-55 and a SMC-DA 50-200
Firmware is 1.3
Lens is properly mounted, I have used the camera for a couple of years
AF/MF switch is on the camera.
I have the same problem on both lenses
05-08-2011, 07:14 PM   #5
Take the lens off of the camera and while moving the AF/MF switch watch the screw drive on the lens mount. In MF it should retract and on AF it should extend. There should be some switch like resistance to moving the lever as well. In other words, it should not just slip from one to the other. I'll assume that you are getting Manual focus in both AF-C and AF-S?
Then, once you've verified that the screw drive is extending/retracting as it should, take a swab with some alcohol and wipe the contacts on the lens and body lens mount. I can't think of one time this has actually worked but it's worth a try. Also, make sure that all of the little contacts on the lens and mount actually protrude a little bit. You should be able to wipe your finger across them in a braille fashion and feel them.
That's about the extent of my help here other than telling you you may have a manual focus camera. To me that wouldn't be a bad thing especially for the price but my tastes don't suit everyone. Fixing it would probably cost more than another camera.
05-08-2011, 07:32 PM   #6
Theswitch does just slip to AF.S to AF.C to MF with little or no resistance. The screw drive doesn't extend when I switch out of manual focus. I guess you're right I have a manual focus camera, but would a lens an auto focus motor in the lens body help at all.
05-08-2011, 07:52 PM   #7
Maybe, and only if it is SDM (Pentax) or HSM (Sigma). Now you're talking some $$$$ but if you want to go that way (and there's no guarantee they will work on that particular camera) it is an option. The good news is if you decide to stick with Pentax, those lenses will work on Any Pentax Digital SLR.
If you want to contact Pentax service, they may give you some idea of the repair cost. If you feel brave and want to try and tackle it yourself,
Downloads
05-08-2011, 08:00 PM   #8
Thank you for the info.
Like your flickr photos BTW.
These are some of the pictures I have taken with my Pentax
Flickr: BiloxiSean's Photostream
05-09-2011, 06:25 AM   #9
Thank you.
Yours are pretty sweet as well. What are you using for the processing?
05-09-2011, 01:47 PM   #10
cardinal43's Avatar
QuoteOriginally posted by biloxisean Quote
Sorry to hear about your camera troubles. Noticed that you are new to the forum and I wanted to wish you a belated "welcome". I grew up just a bit north of you up Hwy. 49 in Hattiesburg. USM - class of '70
05-11-2011, 08:26 AM   #11
Photoshop and photomatix (a little too much photomatix).
I grew up in PA, but now live on the Gulf Coast.
05-11-2011, 06:44 PM   #12
cardinal43's Avatar
You should have seen the Gulf Coast after Hurricane Camille. I was in college then.
camera, mf, pentax help, switch
Stiff On-Off Switch on K7 seachunk2 Pentax DSLR Discussion 4 06-27-2010 07:29 PM
How to switch to Pentax? keyser Pentax DSLR Discussion 18 12-23-2009 03:49 AM
Well, I've made the switch..... maxwell1295 Non-Pentax Cameras: Canon, Nikon, etc. 33 09-19-2009 12:00 AM
The story behind the switch... heatherslightbox General Talk 36 08-06-2009 03:56 PM
Light switch beep41 Post Your Photos! 2 05-21-2009 01:40 PM
All times are GMT -7. The time now is 03:21 PM. | See also: NikonForums.com, part of our network of photo forums!
