Originally posted by cardinal43 I also have this lens, but I have to admit I haven't used it very much. Can you explain a little more about what you said above?
Oh, just that it's only possible to turn on 'macro' mode with the switch when the focal length is at 200-300mm (or thereabouts) so the lens is fully extended. Macro mode allows the focus ring to turn into the gold-marked area, which is where it'll be if you're shooting very close.
However, when the focus ring is in that area, macro can't be disengaged and the focal length is locked at 200-300mm - so anytime I change lenses after using it my usual routine of "retract lens, reverse hood, remove lens" is interrupted by "argh!, manual focus mode, focus to infinity, macro off, auto-focus mode" before I can retract/collapse it.
I guess it's so jarring because my other lenses are quick-shift or MF or don't extend much when zooming/focusing. I've seen other people go through the same process with that lens though, with the same "wtf" expression.
