05-12-2011, 05:10 PM   #1
Denali_Mark's Avatar
Tokina AF 19-35mm & K-5
Just purchased K-5 body. Have a Tokina AF 19-35mm lens that I have enjoyed using with my k10-d. Cannot get this lens to work on K-5. Not sure what issue is.
05-12-2011, 05:19 PM   #2
Have you set the "allow aperture ring other than A" option in the menu? In what sense can you not get the lens to work?
05-12-2011, 05:30 PM   #3
forensicscientist's Avatar
What exactly doesn't work?? You mention its the AF version of lens....so does focus not work? Are all the images dark or blown out or what? Does the lens not mount to the body? Give us a little more detail on exactly what your issue is...lots of sharp people on this forum who are willing to help and advise, just need a bit more detail please.
Thanks,
05-12-2011, 06:33 PM   #4
Sorry for the vague question. When I locked the lens into place, the LCD panel would only read; "F--" and nothing else appeared on the read out. On my K10-d I just locked the lens into place and was good to go. I found that holding down the lens autolock button while rotating the aperture ring did the trick. Thank you both for your responses! Take care.
05-12-2011, 07:01 PM   #5
I'll assume you know how to use your lens. If the aperture ring has an A setting put it there. If it does and is, and still doesn't work, then something is wrong with the contact on the lens. If it Does Not, then go into your custom menu, #5 I think, and set the parameter Allow Aperture Ring to Permitted. It defaults to off when shipped and this type of question gets asked at least once a week. If there is no A setting on the lens aperture, the display will Still say F-- but you'll be able to use the lens.
af, k-5, lens, pentax help, tokina
Tokina AF (235) 3.5-4.5/20-35mm version I & II. Zivelot Pentax SLR Lens Discussion 24 12-07-2014 06:45 PM
Tokina AF 20-35mm Banitess Pentax SLR Lens Discussion 14 08-01-2010 02:03 AM
Tokina 19-35mm and Pentax 18-35 on film? Voe Pentax Film SLR Discussion 19 12-17-2009 12:41 PM
For Sale - Sold: Tokina 20-35mm f2.8 AT-X Pro, Tokina 28-80mm f2.8 AT-X Pro, Tokina 100-300mm f photobizzz Sold Items 7 01-30-2009 06:04 PM
All times are GMT -7. The time now is 02:07 AM. | See also: NikonForums.com, part of our network of photo forums!
