05-16-2011, 01:50 AM   #1
Is it possible to change the direction of the control dials (e-dials) on a K20D?
Somehow they just go the wrong way for me. I use them for aperture & ISO (AV), shutter speed & ISO (TV) and shutter speed & aperture (M). Whenever I want to increase or decrease a setting, somehow my thumb/finger turns the dial in the wrong direction. So can I reverse the direction of adjustment of the two dials?
05-16-2011, 07:46 AM   #2
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by FreddyFrog Quote
Hold the camera upside-down.
Sorry, just had a little smartass attack there. Seriously, no there isn't a way to do that.
I have the same issue. To me, the direction they turn just isn't intuitive.
05-16-2011, 12:13 PM   #3
Ratmagiclady's Avatar
QuoteOriginally posted by Parallax Quote
That's interesting... I actually swapped my front and rear from stock settings, which seems to make everything about how one would expect. Front e-dial becomes shutter and turns the same direction a shutter speed dial does, rear for aperture goes left-right for higher numbers/stopping down.
Don't know if that'd help, but I basically unboxed my K20d, was thrown off by the stock dial assignments, made the switch right off the bat and forgot they don't come that way. Same finger as I'd use for shutter speed with my old Canons, anyway, so it seemed the most natural. And that, at least, 'turns the right way.'
05-16-2011, 03:20 PM   #4
Senior Moderator
Parallax's Avatar
Yes, you can swap functions, what bothers me, and if I understand correctly, the OP is the direction they turn to effect a change. i.e. turning the wheel clockwise has the opposite effect on aperture or shutter speed than it seems like it should have.
aperture, camera, change, control, dials, direction, e-dials, iso, pentax help, photography, shutter
pentax K-7 - annoying e-dials Digitalis Pentax DSLR Discussion 15 05-16-2010 05:05 PM
K7 dials question candgpics Pentax DSLR Discussion 5 03-28-2010 04:46 PM
I nearly fainted when I saw the Mz-M's dials BookSaw Troubleshooting and Beginner Help 3 01-05-2010 08:58 PM
Anyone else notice this about the K-7 dials? PentaxPoke Pentax DSLR Discussion 7 09-29-2009 07:33 PM
customize e-dials on K20D winglik Pentax DSLR Discussion 8 02-11-2009 08:56 PM
All times are GMT -7. The time now is 05:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
