Originally posted by sawicksted Help anyone.
I have been unsuccesful trying to create and avatar. I have silkypix software, photoshop elements, and kodak easyshare software. How do I take an existing photo and resize it to use for an avatar. Then how do I add that to my profile?
I feel stupid asking but for some reason this seems to have me spinning my wheels. I have looked in a lot of places but must have missed something in the threads because I can't find any info on this process.
Thanks in advance for your help with this everyone.
I believe Photoshop E will be the easiest to do this...
Open PSE> along top menu should be >
Image > scroll down >
Resize > scroll to
Image Size... if it's going to be a square image you will end up needing to probably crop it... then Save As > I would use jpeg (should be the same for Mac or PC)
You will need to make sure of a few settings, use pixels not inches and resolution should be set pixels/inch, constrain proportions needs to be checked... and then start plugging in numbers and play around...
Good luck!
