05-18-2011, 10:06 AM   #1
PNY C10 card issue with Kx
I recently purchased 8gb and 16gb c10 PNY cards and I've had issues with both. I get intermittant card errors such as "memory card full" or "cannot display this image."
I've shot mainly in RAW but I have done some JPEG. I've gotten the errors in both formats.
I've been told I have to format the card first, which I did, and that didn't change anything.
I've looked through other threads and it seems the only response is to buy a better card. I suppose I'm not ready to punt just yet.
I haven't had issues with other cards and logically I realize I should simply get something different. But the other cards are C4 not C10 and before I buy something else, I want to make sure it's not the camera.
Is it possible the Kx is haveing issues or is it simply the PNY card? Anyone else experience the same issue?
Thank You
05-18-2011, 11:26 AM   #2
K57XR's Avatar
QuoteOriginally posted by tenthumbs Quote
Where did you buy the cards? The reason I'm asking is if you purchase these on eBay, there is chance that these are not what they're supposed to be...i.e fake.
Did you format the card with the camera or a reader? If you used a reader, I would try formatting the card(s) with the camera.
If possible, have you tried the suspected cards on other cameras, even point-and-shoots using SD cards?
I would also try cleaning the contacts on the PNY.
I use an HP 8GB SDHC C6 and so far the "memory card full" only happened to me once during the past year. I turned the camera off then back on and haven't had the problem since. I'm suspecting for my case it was a contact issue.
Hope this helps!
05-18-2011, 11:52 AM   #3
Thank you for the reply.
I bought one card at Best Buy and another at Fry's. Both new in the package.
Formatted in the camera.
I have three other cards that don't produce this error. That's why I was thinking it could be the camera or perhaps PNY cards simply don't measure up. That seems unlikely but I am open to suggestion.
Thanks
05-18-2011, 01:44 PM   #4
I've tried a PNY Class 10 8GB in my K7 and never saw these errors in my short testing. I ended up returning it anyway because the write performance was worse than my 4GB Sandisk Ultra Class 4.
I've read good things about the Lexar Pro Class 10 cards, which are about as cheap online (~$25 for 8GB) versus the PNY sale price in stores.
05-18-2011, 01:49 PM   #5
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
I have two PNY cards, one 8GB C10 and have not had any of these problems you're having either, and I've got the K-x also. PNY is lifetime warranted, if it were me, I'd contact them.
05-18-2011, 03:47 PM   #6
Thanks everyone. I appreciate the responses.
05-19-2011, 03:07 PM   #7
So much for PNY support:
Hello
Thank you for contacting PNY Technical Support.
Sorry to hear about the problem you have with the PNY SD Card, Seams that these card somehow are not compatible with your camera
I apologize for any inconvenience this might have caused.
If you need further assistance, please reply to this message and we will be happy to assist you further.
Thanks,
Tamer
1-800-234-4597
05-19-2011, 03:21 PM   #8
Sounds like a typical answer where the techie has no clue what is wrong. FWIW, I would have called them rather than use email.
05-20-2011, 08:23 PM   #9
reeftool's Avatar
I have used PNY cards in my K10D almost exclusively since I owned it with no issues of any kind.
c10, camera, card, cards, errors, issue, issues, kx, pentax help, photography, pny
K20D Memory Card Issue George Lama Pentax DSLR Discussion 11 11-27-2009 07:32 PM
Problem formatting PNY SD HC card in K10D Green_Manelishi Pentax Camera and Field Accessories 10 03-10-2009 06:47 PM
What is the better video card? ATI or PNY?? CaymanImaging Digital Processing, Software, and Printing 3 11-22-2008 09:05 PM
For Sale - Sold: FS: PNY 4GB class 4 SD card $20-shipped Tdo0003 Sold Items 3 04-25-2008 09:53 AM
For Sale - Sold: FS: PNY 512MB SD card mediaslinky Sold Items 3 05-23-2007 08:20 PM
All times are GMT -7. The time now is 03:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
