05-21-2011, 07:49 AM   #1
Cosina PK Mount 35-70mm f:3.5
Hi! I grabbed an old, cheap, Cosina PK Mount lens 35-70mm f:3.5. I found that the lens was infested with fungus, so, I tried to dismantle the lens by myself. Perhaps not the wisest decision because I had none experience in that sort of works.
I wasn't able to clean all lenses, since I couldn't unscrew the name ring, so I decided to give up.
Before that I unscrewed the aperture ring and the back of the lens. When I was trying to assemble it back together I noticed the aperture ring didn't stop at each number. Instead, It slided loosely through them.
Well, I figured I may have lost the tiny ball bearing and that turned out to be correct.
The problem is: What is the ball's size? 1.5mm? 1.0? 1.2? I have no idea
I'll be glad if I find some help.
Kind regards.
05-21-2011, 09:52 AM   #2
aleonx3's Avatar
Those tiny ball bearings are usually clinging onto something by static electricity; so chances are they could still be attached on another part of the lens that you took apart. Hopefully you can use the cheap lens as a learning experience. As for the name ring removal, depending on the size, I get one of the those rubber stopper from the plumbing department, and they work well. Make sure you get the right size though. Another option (last resort) is to drill a tiny hole into the ring and then use a small screw driver to unscrew the name ring. The important thing is to have fun taking it apart and re-assembling it back correctly.
aperture, cosina, f:3.5, lens, pentax help, pk
For Sale - Sold: Voigtlander/Cosina 58mm f1.4 SLII Pentax K-mount Lens ***A ST (Worldwide) redfox22 Sold Items 4 02-03-2011 10:05 AM
Cosina discontinuing Voigtlander SLII manual lenses in KA mount tomele Pentax SLR Lens Discussion 50 10-01-2010 11:15 AM
Cosina 1.2 - Will only mount wide open? Cedromar Pentax SLR Lens Discussion 4 03-10-2010 06:49 PM
Cosina K-mount SLR fan thread nater Non-Pentax Cameras: Canon, Nikon, etc. 2 09-14-2009 07:09 PM
For Sale - Sold: Tamron 28-200mm, Tokina 28-70mm, Cosina 75-300mm, and some BGN stuff edl Sold Items 14 04-28-2009 02:16 PM
All times are GMT -7. The time now is 06:21 AM. | See also: NikonForums.com, part of our network of photo forums!
