Originally posted by MK-x Do you mean that all 'superzoom' lenses are not suitable for low light?
Actually (a dumb question
) , what does it mean "not suitable for low light"? In what way?
You should read up a bit about the elements of exposure: aperture (f-stop), shutter speed, and sensitivity (ISO). To shoot in low light, you need to do some combination of:
* a wide aperture (but superzooms don't open much),
* a slow shutter (which may require a tripod), and
* boosting ISO (which increases noise in the image).
A superzoom is "not suitable for low-light shooting" because its aperture cannot be opened very far -- its best is typically f/3.5 to f/5.6, which is pretty 'slow'. A 'fast' lens may have a maximum f-stop of f/2 or f/1.7 or f/1.4. [NOTE: an f-stop is a fraction, the ratio of a lens' maximum opening to its focal length. Just as 1/2 is a bigger fraction than 1/4, so f/2 is a larger opening than f/4, letting more light in.]
Faster lenses are expensive to design and build. Fast zooms are even more complex and expensive. Fast superzooms are virtually impossible to produce economically, which is why they don't exist. So, superzooms are necessarily 'slow'.
And some superzooms show "zoom creep". Put an excellent DA18-250 onto a tripod-mounted camera, aim it downwards, and it will tend to 'creep' out to 250mm, no matter where you actually want it. So in low light, it's not suitable for handheld use; and it's not suitable for tripod use unless it is kept absolutely level, or taped into position, or sandbagged.
So you can either boost the ISO (and get more noise), or use a faster lens. Those are the cold hard facts.
Quote: can you give me an example of a "manual focus lens"? a model or a link.
Look here: [
Pentax Reviews - Pentax Lens Reviews & Pentax Lens Database ]
Everything below the entry F-SERIES ZOOMS is a manual lens.
A manual focus lens is just that -- you manually twist it to focus it, no electric motors involved. Many of us prefer older manual focus lenses because 1) they have a different 'look' than newer lenses, and 2) they can cost much much less. Of my over 200 lenses, about 10 are AF, the rest are manual focus (MF). On average, AF lenses cost me US$330 each, and MF lenses cost me US$20 each. I can buy many many old MF lenses for the price of one new AF lens. I'm a cheap bastard, so that is important to me, eh?
