05-22-2011, 07:07 AM   #1
Lens fit slop
Folks
I recently purchased a Tamron 70-200 2.8 (New) and I notice the lens mount fit has considerably more rotational (radial) slop than any of my three Pentax lenses. The camera is a new K5. I can not give a hard measurement on the amount of rotation but do get a distinct and noticeable amount of motion as I rotate it back and forth. It does not take much effort to move it. the fit is snug axially with no noticeable movement.
My Question: Is this sort of movement in the mount acceptable? If so, is there any practical way to determine when it reaches a degree where it is not acceptable?
Thanks for any help.
Best regards,
Wayne
05-22-2011, 07:15 AM   #2
Ash
Community Manager
Ash's Avatar
Welcome here Wayne.
Generally, lenses should have minimal play in any direction.
But does your lens focus accurately, and does manual focusing operate smoothly on your copy?
If not, this would be good grounds to have the lens exchanged. Otherwise, have the lens looked at by your local lens repairer if you're not certain about the relevance of the radial play of the barrel. It may be nothing to worry about if it is otherwise operating as normal.
05-22-2011, 07:20 AM   #3
The lens does seem to focus properly and operate acceptably in all other regards. I guess my main concern is wear and tear on mount surfaces, both camera and lens, over time.
Thanks for the quick response.
05-22-2011, 07:25 AM   #4
Additionally, I am curious to know if this particular characteristic is normal for this, or other, model of Tamron lens. If it is "par for the course" I will likely just live with it. If not, i.e Tamron lenses normally fit as snug as OEM, I will likely return for another copy. The problem with the second option is that it will likely result in having to wait for several weeks for the new one to arrive.
Best regards,
Wayne
05-22-2011, 07:46 AM   #5
Ash
Community Manager
Ash's Avatar
There have been previous threads about lens barrel play in lenses, not just Tamron ones, and generally it's of no consequence unless the lens is clearly falling apart. In these cases, it would be a matter of tightening some of the screws, and it's usually fixed. No minor lens play should affect a lens's life or that of the camera it is mounted on.
amount, fit, lens, mount, movement, pentax help, slop
So I need a 47mm lens hood to fit my 50mm lens? lovemehate Troubleshooting and Beginner Help 15 04-18-2011 12:51 AM
will the lens fit? kschmitt Troubleshooting and Beginner Help 4 01-12-2011 09:09 PM
Will this lens fit my kx? 4ngi3 Troubleshooting and Beginner Help 13 06-30-2010 11:33 AM
Oh no! I got a lens that won't fit! Ouroboros Troubleshooting and Beginner Help 15 03-23-2010 08:12 AM
Will this lens fit my kx ??????? spanky66d Troubleshooting and Beginner Help 7 02-18-2010 03:23 PM
All times are GMT -7. The time now is 04:37 PM. | See also: NikonForums.com, part of our network of photo forums!
