05-23-2011, 07:33 AM   #1
Manual flash on K-X
Have bought a used Achiever 260AF flash to use with my K-X.Haven't used it on the camera yet,still making sure the trigger voltage is OK.Am comfortable using manual flash but would like to know what setting should be used to let the camera auto focus but user set the speed and aperture.Would be nice if the low light assist on the flash could be made to work.
Thanks,
Jake
05-23-2011, 08:07 AM   #2
enoeske's Avatar
QuoteOriginally posted by bjake Quote
Thanks,
Jake
Manual mode would work fine to let you set the shutter speed and aperture yet still auto focus. As would TAv mode, however, then you are stuck with auto ISO.
05-23-2011, 08:19 AM   #3
Thanks,didn't know auto focus would work in manual mode as I have only used manual lens in this mode.
Jake
05-23-2011, 08:34 AM   #4
enoeske's Avatar
Jake
manual focus and manual mode are two separate things
05-23-2011, 08:56 AM   #5
DaveHolmes's Avatar
You know you woun't be able to fire the flash at speeds of over 1/180th right?...
Don't know that flash... does it have manual control or just fire at 1/1?
But yeah... like he(^) said... Manual mode... Leave the auto focus on... Jobs a good 'un!
05-23-2011, 04:25 PM   #6
QuoteOriginally posted by DaveHolmes Quote
Can't fully answer your question but believe it does have some kind of auto mode
but don't know if the auto mode works on my camera,don't have a user guide.This is what was found searching the web.
Jake
Guide Number 86 @ ISO 100
Flash Type What is "Flash Type"? Regular Flash
Zoom Range 28 - 85 mm.Achiever 260AF Flash for Minolta Maxxum
Power and features combine to make this one of the most versatile dedicated autofocus flashguns. A bounce head with zoom action to cover...
Power and features combine to make this one of the most versatile dedicated autofocus flashguns. A bounce head with zoom action to cover lenses 28-85mm makes the most of flash lighting. Built in AF illuminator allows focus even in total darkness. Thyristor circuitry and exposure check indicator. Wide angle diffuser and filter set included. Range up to 17m / 57ft.
Mount Type Hot Shoe Mount
Weight 8.8 oz.
Other Features
Bounce With Bounce
Min. Recycle Time 6 Seconds
camera, flash, pentax help, photography
Flash with new manual lenses Urmas R. Flashes, Lighting, and Studio 4 04-28-2011 06:43 AM
Manual Flash Question(s) bluebronco Troubleshooting and Beginner Help 9 04-21-2011 09:37 PM
What is a manual flash? justtakingpics Troubleshooting and Beginner Help 7 04-12-2011 02:35 AM
Manual Flash Control krebsy75 Flashes, Lighting, and Studio 18 02-07-2011 03:13 PM
Need flash manual or guide number hillerby Flashes, Lighting, and Studio 9 07-24-2009 11:55 PM
All times are GMT -7. The time now is 02:20 AM. | See also: NikonForums.com, part of our network of photo forums!
