05-23-2011, 09:46 AM   #1
Farmer_Terry's Avatar
Folders created by the camera
I have read a couple of threads about folders created on the card in the camera, but no one has asked if there is a way to eliminate them.
I really don't like the images being created in folders, it just doesn't work for me. I hold all my photos in folders on the computer, but there is more than one person in my family taking photos (with different cameras) and we have our own system which works well.
Until I come to get the photos off my K-x. I have seen there is an option that toggles between two different forms of folder name, but is there any way I can stop the camera creating folders completely?
Any help very gratefully received.
05-23-2011, 10:35 AM   #2
blackcloudbrew's Avatar
Check your manual of course. I don't have a K-x but my K10/20/100ds/5 all have the option to store files in folders by date or not. I have all my cameras set up that way, but recall that this was not the default setting in the menus.
05-23-2011, 11:04 AM   #3
Just1MoreDave's Avatar
You have a choice in the Setup 2 menu between Date and PENTX. If you choose PENTX, the card will have a folder called DCIM, and a folder within that named 100PENTX. Then all your photos will be in that one folder, except if the card has over 500 photos on it. Then the camera will create a second folder named 101PENTX, and so on for each group of 500.
I think the camera also creates a new folder if you go from IMGP9999.xxx back to IMGP0000.xxx. If the camera does create a new folder name, I rename it back to 100PENTX after downloading the images and keep all my cards the same.
As far as I know, that's the minimum number of folders on a card.
More info is on p. 252 of the K-x manual, p. 279 in the K-r manual. The K-7 is similar to the K-x.
05-23-2011, 11:29 AM   #4
Marc Sabatella's Avatar
If the camera didn't create folders at all, most software wouldn't know how to access the images. There are standards for this sort of thing, and cameras and software about adhere to them.
but whether there are folders on the card or not should have no bearing on where you put the pictures on your computer. Any photo downloading program worth anything would give you options to control where your downloaded pictures go - you aren't compelled to keep the camera's folder structure at all.
05-23-2011, 11:56 PM   #5
Thanks all for the replies - so it looks like the answer to my question is no.
I am perfectly happy to have a folder - I would just like it to be the same folder. My Fuji also creates a DCIM folder, but it then stores all the photos directly in it. No sub-folders. They are always in the same place. On my Pentax the name of the source folder varies depending on how many "shoots" I keep on the camera.
Any photo downloading program worth anything would give you options to control where your downloaded pictures go.
That's true, but I use a general file transfer program called Beyond Compare for all this type of thing and, because it stores frequently used tasks, it would be a lot easier if the source were always the same folder.
There are always ways round these things, but just putting all the photos (OK - I can live a 500 image max) in one place would, for me, be a big help.
Having had a gripe I must say I love my new K-x.
Thanks again for the help.
05-24-2011, 02:18 AM   #6
Stone G.'s Avatar
QuoteOriginally posted by Farmer_Terry Quote
I am perfectly happy to have a folder - I would just like it to be the same folder. ......
........ but just putting all the photos (OK - I can live a 500 image max) in one place would, for me, be a big help.
But this is exactly what you can do with your K-x (up to 500 images). Consult you manual, "Setting the Image Naming Convention". (Or go directly to the Set-up Menu and find "Folder Name" there).
Note: If I were you and for several reasons - including safety - I would normally empty my card long before I have 500 pictures on it.
05-26-2011, 09:50 AM   #7
Thanks. I have set the folder name to xxxPENTAX and, if the folder 101PENTAX only gets created once the number of stored images gets to 500, that is indeed exactly what I want.
500 images will take me a year, even if I see my granddaughters every week and I do clear the images off very frequently, so I am unlikely ever to get close to that number.
Thanks again everyone.
camera, folders, pentax help, photography, photos
dumb f-stop question - all f-stops created equal? minimalist Pentax SLR Lens Discussion 18 11-19-2010 05:17 PM
Created website, interested in feedback pb_red Photographic Industry and Professionals 6 02-19-2010 06:22 PM
LBA created more questions sinus007 Pentax SLR Lens Discussion 8 06-06-2009 08:46 AM
Folders created offertonhatter Pentax DSLR Discussion 4 02-05-2008 05:39 PM
SD Card Folders HOGFan Pentax DSLR Discussion 4 01-03-2008 11:00 AM
All times are GMT -7. The time now is 11:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
