Originally posted by sany How to make a monitor caliberation for photography and make sure the laptop monitor and the camera monitor look same. Even some kind approximation will also be helpful.
Any ideas for free software that can do this - i dont need to be very accurate to go and spend bucks on these hardwares.
Home made solutions are welcome!
thanks
If you're on a Mac, the Monitor Calibration tool found in Preferences is not bad. System Preference > Hardware > Displays > Color > Calibrate
On a PC you can click on your Graphic Properties and depending on what you have, you may be able to calibrate monitor.
I am almost sure most software like Photoshop/Elements or Corel Paint Shop will have a Monitor Calibrating Tool.
These will calibrate your monitor so you can view images/color/contrast properly but this does not mean the same thing in regards to printing. Printing what you see on your computer monitor is another entire challenge.
Good link:
Monitor calibration and setup for photography and printing
*One last thing, if you're finding the images displayed on your computer are different than on your camera, that is usually due on the software you are using to download and view your images. Some say, it is sometimes best to use the software that came with your camera outfit if you want to process your images similar to your in camera files...
