05-27-2011, 06:57 PM   #16
Lowell Goudge's Avatar
Can you post a photo of the adapoor you actually have? And the back of the lens
The one you linked should work fine as it had no rear flange the rear flange would, on the smc tak lock the aperture because it would hit the aperture coupling used on spotmatic ESII and F cameras for open aperture metering. It also could be something in your body. Specifically the electrical couplings. Can you post 3 shots. One of the adaptor on it's own, one with the lens screwed onto the adaptor but not in the camera. Shoot the rear of the lens for this. And the last of the adaptor set onto the camera with no lens mounted.
If my guess is right you will need to probably mount the lens first on the adaptor but not screw the lens into the adaptor when mounted to the camera
05-27-2011, 07:56 PM   #17
I understand now. Thank you.
You have M42-EOS adapter similar to this:
and the lens hits the inner part. Full focus range of lens is not possible, as you say.
The M42-EOS adapter without "flange" is necessary for this lens:
Inexpensive on ebaY. I recommend seller BigIS. Ask him for "flange-less" type M42-EOS adapter.
05-27-2011, 10:37 PM   #18
QuoteOriginally posted by rhodopsin Quote
Ohhhh that's it my friend. I have a BigIS black mount adapter, but it has flange. I'm now asking to the seller for an adapter without it. Thank you very much!!! I hope that thing can fix my issue, you were really kind. Thank you so much.
50mm, adapter, pentax help, tak
Super-Tak 50mm/1.4 versus Leica Summilux 50mm DanielT74 Pentax SLR Lens Discussion 47 01-19-2011 11:10 PM
For Sale - Sold: Pentax DA 12-24mm f/4, 50mm M f1.4, Tak. 135mm f2.5, Tak. M42 55mm f1.8 (US) DenverDutchman Sold Items 2 11-25-2010 10:06 AM
For Sale - Sold: Pentax 50mm A&M f1.7, 50mm m42 f4 macro, 70-210mm Tak-F, Panasonic FZ28, ballh pxpaulx Sold Items 13 09-16-2009 09:47 AM
For Sale - Sold: SMC Tak 150mm/4, SMC Tak 135mm/3.5, Super Tak 55mm/2 and extras pdxbmw Sold Items 8 09-10-2009 10:54 AM
All times are GMT -7. The time now is 03:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
