05-25-2011, 09:05 PM   #1
Help me with my S-M-C TAK 50mm 1.4 issue
Hi guys! I bought recently a Super Multi Coated Takumar 50mm 1.4 and I cannot focus properly and change the diaphragm it's stacked. I tried with two differents mount adapter to my Canon EOS 60D (both of them were from China).
Does someone could figure it out which it's the best adapter for the TAK 50mm? I want to buy the right one.
Please, help me.
Thanks a lot!!!
05-26-2011, 03:39 AM   #2
raymeedc's Avatar
QuoteOriginally posted by alanpierrotcine Quote
I don't understand why people will spend thousands of dollars on lenses & cameras, then they to save a few bucks (literally) by purchasing a cheap Chinese knockoff adapter. Many have problems with these adapters. In your case, you've probably already exceeded the price of the genuine article by purchasing two! Bite the bullet & buy the real thing from the Pentax site, only $30.
05-26-2011, 03:41 AM   #3
Kim C's Avatar
I didn't know Pentax did an adapter to fit a Canon EOS 60D
Kim
QuoteOriginally posted by raymeedc Quote
05-26-2011, 03:55 AM   #4
raymeedc's Avatar
QuoteOriginally posted by Kim C Quote
Kim
My mistake..... that's what you get for posting when you're not yet quite awake..... I was, of course, referring to the Pentax to Pentax adapter. Consequently, in this prevailing case, my advice would be the obvious..... sell your Canon & buy a Pentax!
05-26-2011, 04:45 AM   #5
Lowell Goudge's Avatar
on SMC Tak's there is a tiny pin that needs to be pressed to release the manual auto switch, that usually gets depressed when the lens is screwed onto the adaptor (or some times the lens cap.
that should let you put the lens into manual aperture mode.
on the camera you should then be able to change the aperture using the aperture ting.
Focusing , I don't understand, can you turn the focusing collar? does the barrel of the lens move in and out. If so, you should be able to reach focus on the camera.
have you checked your eyepeice diopter setting to make sure that it is correctly set for your eye sight? you should be able to see what ever marks are on the focusing screen clearly
05-26-2011, 05:41 AM   #6
Kim C's Avatar
Seconded!
Kim
05-26-2011, 05:43 AM   #7
I think it's because the focus barrel it's longer than the mount adapter. When it's in INFINITY the barrel slides over the adapter, I need a new one. But I don't know which brand to buy.
05-26-2011, 06:13 AM   #8
If I'm understanding your post properly, you have a different problem. The Taks should not have focus rings turning past the adapter. In fact, I don't even see how it could with the Aperture ring and the A/M switch in the way.. On a Pentax camera, the rear of the lens mounts flush to the lens mount.
05-27-2011, 10:20 AM   #9
Someone is using this adapter for this lens?
Fotodiox Black M42 Lens to Canon EOS Mount Adapter - eBay (item 350245655977 end time Jun-19-11 08:03:05 PDT)
05-27-2011, 10:37 AM   #10
please review and answer my previous questions. Note all adjustments are made through the lens not the camera. so if the focus collar moves and the aperture ring moves and changes the aperture with the lens on it';s own it will work.
also consider that not all cannon cameras will take a picture without focus confirmation, there are M42 adaptors that permit this
M42 - Canon EOS Lens adapter | AF Lens Adapters | peleng8.com - Peleng 8mm f/3.5 Circular Fisheye Lens for Canon, Nikon, Olympus
05-27-2011, 10:38 AM   #11
eddie1960's Avatar
From a 3rd party adapter standpoint I understand the Fotodiox are about as good as they get (I use original Pentax because I shoot on Pentax)
05-27-2011, 10:56 AM   #12
Rense's Avatar
'I've got me a pentax adapter. Can someone tell me what camera would be best with this adapter?'
05-27-2011, 06:15 PM   #13
When I put the adapter to the lens, I can't move the focus collar from 1.2mt to Infinity and also the aperture ring it's like stack. Why my friends?
05-27-2011, 06:29 PM   #14
Hi Alan, welcome to the forums!
I don't understand, what is meaning of "it's stacked"?
With lens not mounted on camera, and lens Auto/Man switch in Man position, the focus ring and aperture ring should turn fully. Turning aperture ring should operate diaphragm.
If can not switch Auto/Man to Man position, first depress the tiny pin on the lens rear.
05-27-2011, 06:40 PM   #15
QuoteOriginally posted by rhodopsin Quote
I have the same issue that this guy
Flickr: Discussing Tricky Super Multicoated Takumar 50mm f1.4 to EOS in M42 Lenses and DSLR's
Please read the first part. Thanks my friend
50mm, adapter, pentax help, tak
Super-Tak 50mm/1.4 versus Leica Summilux 50mm DanielT74 Pentax SLR Lens Discussion 47 01-19-2011 11:10 PM
For Sale - Sold: Pentax DA 12-24mm f/4, 50mm M f1.4, Tak. 135mm f2.5, Tak. M42 55mm f1.8 (US) DenverDutchman Sold Items 2 11-25-2010 10:06 AM
For Sale - Sold: Pentax 50mm A&M f1.7, 50mm m42 f4 macro, 70-210mm Tak-F, Panasonic FZ28, ballh pxpaulx Sold Items 13 09-16-2009 09:47 AM
For Sale - Sold: SMC Tak 150mm/4, SMC Tak 135mm/3.5, Super Tak 55mm/2 and extras pdxbmw Sold Items 8 09-10-2009 10:54 AM
All times are GMT -7. The time now is 05:22 AM. | See also: NikonForums.com, part of our network of photo forums!
