Originally posted by Ragnar DA*16-50
Sigma 105 Macro
DA 55-300
I might add a Teleconverter anyway. Can't wait to try out whats possible with it.
Any recommendations which TC would go along with these lenses ?
Those lenses aren't really good candidates for a TC. I think you'll find that most quality TC work (often birding) involves specific TC's that are matched to some specific longer lenses. You have chosen all AF lenses. AF TC's are not cheap, and as mentioned, they won't really provide better IQ than if you just shot and cropped.
A-type TC's cost less but don't support AF. M-type TC's are dirt-cheap but support neither AF nor aperture automation. If you think you'll want a TC, try a dirt-cheap one first. Then it won't hurt so much financially when you discover that it is useless.
NOTE: I have a couple M-types that I don't use, and an M-type macro-TC that I may use someday, when I'm bored. I have a couple A-types from which I've removed the glass, so they function as extension tubes, good for flash work. And I have a bunch of M42 TC's, two each 2x and 3x. One of these days, I'll put all those M42 TC's on my Rubinar Makpo 1000/10 mirror and have a 10,000mm f/100 lens! Hmmm, I wonder just what I will DO with that...
_____________________________________________________________
ObTopic: For a lens kit, think about what you want to do that you can't do with what you already have. My first Pentax kit was the K20D, DA10-17, DA18-250, and FA50/1.4, because I wanted ultrawide / fisheye, superzoom / walkabout, and FAST. (I later added macro.) The Tamron 10-24 now supplants the DA10-17 for most wide shots. The DA18-250 is my basic lens; all my 200+ other lenses are for specialty work. I shoot a lot between 35-70mm and find that swapping lenses at ~50mm is intolerable, so I very much dislike 16-50 or 18-55 plus 50-200 or 55-300 kits.
So your lens choices should reflect what you want to shoot, and where you want to swap lenses. An 18-250 or 16-135 or something in those vicinities will be a good walkaround. An 8-16 or 10-20 or 10-24 will be very useful in small spaces. The 100WR macro is excellent for macros, headshot portraits, general short tele work. A Fast Fifty will be great for other portraiture and for low-light in general. Those are the 4 lenses I would start with.
And then I started buying cheap manual primes, and met my doom. Argh!!
