05-27-2011, 06:05 PM   #1
RAW image quality question
I was looking at dpreview and saw that the k-5 had better image quality than almost any camera and was equal to the pro Nikon and Canon in RAW image quality (not jpeg).
Isn't that RAW quality the most important thing? Isn't that "better" than jpeg quality if you are post processing your images and can't you get better jpeg quality than the camera anyway if you are good enough?
05-27-2011, 06:32 PM   #2
Yes. Yes and yes.
05-27-2011, 07:25 PM   #3
Ash
Community Manager
Ash's Avatar
See your other thread for more on this.
The RAW and JPEG comparisons have been discussed many times on this forum.
It would behoove you to do a search and read up on it or just search the net in general about the differences and applications of the image formats.
05-27-2011, 07:29 PM   #4
I don't think I asked clearly then because I'm only talking about RAW image quality between different cameras. I understand the benefit of shooting RAW versus JPEG. But if RAW is better on one camera won't that mean I can get a better jpeg in the end, if I do my own PP?
05-30-2011, 09:22 AM   #5
RioRico's Avatar
QuoteOriginally posted by justtakingpics Quote
RAW data is just a dump of what the sensor sees when the shutter is pressed. Different camera makers use different defaults for in-camera processing of the RAW data to a JPG, and you can of course use your own in-camera settings. If you can outsmart the camera and its design engineers, you can get 'better' JPG's from your PP work.
More importantly, you can get different JPG's than the in-camera processing can provide. Whether those differences are 'better' is an aesthetic matter, not engineering. What you think you see, what you want to see, and what the camera sees (if anything), are all different. With RAW, you get to work with what the sensor has, and make it produce what you want to see. I sometimes generate a couple dozen different JPG's from one RAW file. Which is 'better'? That depends on how I want the picture to look.
Overall differences in IQ will depend on how that sensor was engineered, and the lens of course. So yes, a 'better' sensor implementation will allow you to make 'better' JPG's, whatever 'better' means to you. But unless you're doing technically critical work, it likely doesn't really matter.
05-30-2011, 11:26 AM   #6
I didn't read every word on dp review, but my impression was that they thought the K5 was an excellent, but significantly overpriced, camera. I didn't see where it was considered having equal image quality vs. current-generation full-frame cameras.
Paul
05-30-2011, 03:53 PM   #7
QuoteOriginally posted by tibbitts Quote
Paul
If you look at the sliders on the final page it has the k-5 the same as the pro-level cameras on raw image quality....whatever that means.
camera, image, image quality, jpeg, pentax help, photography, quality
Question about image quality of the k-7 justtakingpics Pentax DSLR Discussion 18 05-15-2010 05:30 AM
Image quality question and be nice pakuchn Pentax DSLR Discussion 52 01-25-2010 11:56 AM
K10d image quality question/issue vagabond79 Troubleshooting and Beginner Help 7 11-12-2009 12:29 PM
Question about printing and image quality. triplej96 Pentax DSLR Discussion 11 11-18-2007 09:09 PM
Pentax K10D - RAW or jpeg for maximum image quality? rrobinson54 Photographic Technique 31 09-09-2007 11:43 PM
All times are GMT -7. The time now is 01:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
