06-03-2011, 10:10 PM   #1
I need help!!!
I have a pentax K-r and i love it, but i recently encounterd a problem, when i wanna go shooting in the dark/night and put the camera in any certain shooting mode, the shutter speed, ISO, and F stop flash or blink as if that my lense cap is on, please help
06-03-2011, 10:36 PM   #2
Ash
Community Manager
Ash's Avatar
It's telling you for that scene there is insufficient light for the camera to meter the shot with the settings provided. If you know what settings you need for the shot, don't worry about it, just press the shutter release button.
06-03-2011, 10:42 PM   #3
MJL
MJL's Avatar
What lens?
What lens you are using? May be the aperture ring on the A-series lens is not lock on "A". My M-series lens will do the same, but without the F display.
06-03-2011, 10:53 PM   #4
Ash
Community Manager
Ash's Avatar
QuoteOriginally posted by MJL Quote
I believe the OP is referring to the viewfinder display parameters, in which case it's a metering discrepancy the camera is finding hard to adjust for in the given setting.
06-04-2011, 07:04 AM   #5
Try this.
Set your camera to Tv (shutter Priority) so you can dial in a fast enough shutter speed to avoid camera shake in the photo.
Make sure your ISO is on Auto and that you have enough range to cover your situation.
Chances are, the camera will shoot with the lens wide open at this point. If it does, and you don't want it to, go to M mode, set your shutter speed and aperture where you want it, then adjust ISO until everything stops blinking. The Blinking is an exposure warning.
06-04-2011, 11:20 AM   #6
hanx guys, but the lcd screen blinks when i know there is sufficient light to meter its strange, i ddnt have this problem with my previous pentax
06-04-2011, 04:46 PM   #7
Ash
Community Manager
Ash's Avatar
What are the settings being displayed when you notice the blinking?
It also blinks due to gross overexposure - it's an exposure warning for both ways.
06-05-2011, 05:08 AM   #8
Lowell Goudge's Avatar
QuoteOriginally posted by iammokster Quote
No they just set the exposure to the minimum it could measure without telling you
06-05-2011, 10:18 AM   #9
thanx guys got the problem solved
pentax help
All times are GMT -7. The time now is 02:42 AM. | See also: NikonForums.com, part of our network of photo forums!
