Hi everyone,
I have a problem keeping me from using my k100D Super.
Not so long ago, my 3 year old K100D Super started giving me the "card locked" message. One moment I was taking pictures, the next one this message showed up.
It did not fall, there was no impact of any kind.
Simply stopped working.
I checked the card, the switch was on the 'unlocked' position. I checked other cards (SanDisk, Kingston) and none worked (these work on other devices). I was obliged to put the camera back in my bag.
Days later, after trying a lot of blowing in the slot and everything, I managed to use it again for 2 pictures since it unlocked while it was on! Turned it off, turned it back on, it wasn't working anymore. Never worked since.
Removed the batteries so it would reset the firmware or whatever, didn't work.
Tryed SD cards with some tape around, didn't work.
Blew a lot, didn't work.
There is a thread with a similar problem for a K10D (
https://www.pentaxforums.com/forums/pentax-dslr-discussion/77529-k10d-card-locked-2.html ), but with no solution nor conclusion.
Is there anything I can do to fix it?
