06-06-2011, 03:48 AM   #1
off camera flash
Hi
I have a Pentax Kx DSLR and a Toshiba flash unit.
The flash is about 30 years old and still works.I have read that older flash units may damage the circuits in the camera.
The flash uses a bracket to sit along side the camera and a pc cable connects to a hot shoe adaptor to allow the camera to fire the flash
I have tested the camera/flash a few times with no problems. How can I find out if the flash will damage the camera if I continue to use it?
Hope you can help
Thanks
Warren
06-06-2011, 03:57 AM   #2
Ash
Ash's Avatar
Check the flash's trigger voltage rating.
The most comprehensive source for this information is here: Photo Strobe Trigger Voltages
06-06-2011, 04:02 AM   #3
If the site Ash pointed you to doesn't have your flash listed, buy a digital multimeter (they're pretty cheap, I bought one for around $7) and check the trigger voltage. It's fast and easy to do.
Actually, even if your flash is listed, it's not a bad idea to check your unit yourself.
06-06-2011, 10:37 PM - 1 Like   #4
krypticide's Avatar
If it's high voltage, you can consider using a wireless trigger. Something cheap like the Cactus V5 might be good enough if you always have your flash on a bracket.
06-11-2011, 06:05 PM   #5
what is Kx flash trigger rating?
Thanks to all who have relied.
Having read the replies can anyone tell me what the trigger rating is for the Kx?
I have sent an email to Pentax but as yet no reply
Hopefully in the next day or so I will try to check the flash to see what is is
06-12-2011, 08:32 PM   #6
Just1MoreDave's Avatar
QuoteOriginally posted by wazzau Quote
It is difficult to get Pentax to answer this question. I've read that all Pentax brand flashes are safe and they all have pretty low voltages.
In your case, you need a connector to go from the camera hotshoe to the PC cable you have. You can buy a connector that also keeps the voltage at the camera down to a safe level. That solves both problems.
06-13-2011, 06:40 PM   #7
DaveHolmes's Avatar
get a safesync hotshoe adaptor or use cheap wireless triggers... sorted... safe...
camera, damage, flash, pentax help, photography
For Sale - Sold: Metz 48 AF-1 Flash; Pentax off-camera flash cable set (Adapter F, FG (US/UK/CA bigben91682 Sold Items 4 10-12-2010 04:23 AM
For Sale - Sold: Sunpak Auto511 off-camera flash and bracket, Large Quantaray black camera bag pxpaulx Sold Items 3 02-11-2010 09:06 PM
For Sale - Sold: Wireless flash triggers for off camera flash kenyee Sold Items 3 11-06-2009 01:20 AM
Off Camera Flash Hey Elwood Photographic Technique 4 06-20-2009 07:32 PM
Mixing off camera manual & on camera p-ttl flash srclark Pentax DSLR Discussion 8 12-29-2008 08:52 AM
All times are GMT -7. The time now is 11:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
