Originally posted by Run_Lola If I switch my camera to manual focus mode, will the autofocus lens allow me to work manually? Or do I need a manual focus lens? Thanks for the link, very helpful.
First, you could try some practice shots and see what your camera does. I might be wrong about the fence.
There's a couple of ways to adjust if AF has a problem. You can choose the one that works best for you.
One is a switch on the front of the camera, on the side opposite the shutter button, on the side of the lens mount. You can slide that to MF, and focus the lens manually by turning its focus ring.
Another way is to use a button on the camera to turn AF on and off. On the K-x, you'll have to change a Custom Setting on page 2, item 10. You can choose the normal way your camera works, Enable AF1, or have your camera only auto-focus when you press the AF button, or have the AF button cancel AF when you're holding the button.
In either case, the viewfinder will display MF to tell you that you have to focus manually. You should wait for that indication before turning the focus ring on the lens. Because the cars are going to be zipping by, probably too fast to focus on the fly, focus on a spot before the cars get there, then hit the shutter when the car arrives. This technique might make the Cancel AF option a little trickier, as you will have to be sure you are always holding the right buttons to keep the camera from refocusing away from your chosen point.
Pentax has a lens feature called Quick-shift Focus that allows you to turn the focus ring at any time to adjust focus, without a lot of button-pressing. They left it off all of the DA-L lenses, which is a little annoying. I think all the DA lenses have it except the DA 18-250, which is discontinued.
