06-12-2011, 06:14 AM   #1
[langtitle=bg]Problem with telling the camera (Pentax 100D) what the foca[/langtitle]
Hi,
I hope somene can help me with my problem.
When I use manual focus lens I need to tell the camera what the focal length is of the lens being used to get the best SR performance.So to do this, I simply turn the camera off, mount the lens, make sure SR is ON, turn the camera back on, and ..... nothing happens.I don't get the menu where I can select the focal length of the lens being used on the rear LCD when prompted.
When I go in the Menu manually to do this(shake reduction can not be accessed (if a manual lens is mount on the camera)
What should I do?
Thx
06-12-2011, 06:49 AM   #2
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
On my K100D, with manual lens mounted, as soon as I turn on the camera, there is a list of focal lengths showing on the LCD, that allowed me to change the focal length with the four way controller. Are you saying this is not showing up on your LCD?
06-12-2011, 07:14 AM   #3
yes this is not showing up on my LCD and I tried with 2 different manual lenses. Also the camera does not confirm with the green <_> that I am on focus with manual lenses.
06-12-2011, 07:17 AM   #4
Have you taken an image and looked at the detailed information on the rear screen to see what focal length it thinks it has mounted?
06-12-2011, 07:29 AM   #5
AOShep's Avatar
Check is SR is turned off. I think you will only get the prompt for focal length if shake reduction is turn on.
06-12-2011, 07:30 AM   #6
no, I haven't but that's a really good idea. Thx !!!!
06-12-2011, 07:36 AM   #7
QuoteOriginally posted by AOShep Quote
SR is turned on ,Mode is on M and focus on M, I triple checked it!When I turn on the camera Still doesn't that allowed me to change the focal length.
06-12-2011, 07:49 AM   #8
How's your battery level? I've found if the batteries aren't up enough, the LCD can't work.
06-12-2011, 08:31 AM   #9
glee46's Avatar
What lens are you using?
What camera & lens are you using? Just a guess, but it could help with the answer.
06-12-2011, 08:37 AM   #10
Make sure that "using aperture ring" is set to permitted. Push the menu button and go the custom setting tab, should be on the third page of the custom setting menu.
06-12-2011, 09:20 AM   #11
QuoteOriginally posted by photolady Quote
hi, battery level is full!
06-12-2011, 09:21 AM   #12
QuoteOriginally posted by glee46 Quote
hi, camera : pentax k100d, lens : Asahi Super-Multi-Coated Takumar f1.4/50 mm.
06-12-2011, 09:28 AM   #13
QuoteOriginally posted by MPrince Quote
hi, "using aperture ring" is permitted,but I still have the same problem.
06-12-2011, 09:35 AM   #14
QuoteOriginally posted by interested_observer Quote
hi, I just did this and there is no info about the focal lenght in the detailed information of a taken image. There is just " --mm".
06-12-2011, 09:49 AM   #15
Are you setting Shake Reduction via the menu or the button on the right bottom of the camera?
camera, length, lens, menu, pentax help, sr
pentax k100d super shutter problem All-marss Troubleshooting and Beginner Help 5 05-23-2011 02:53 PM
Problem med Tamronobjektiv och inbyggd blixt Stjarneback Pentax K-r 8 05-18-2011 01:52 PM
Fotos de la K7 negras al editar con PENTAX Digital Camera U yuqui Troubleshooting and Beginner Help 10 02-15-2011 06:44 PM
Pentax 67 TTL Prism Problem dellos Pentax Medium Format 3 02-08-2011 05:02 AM
Pentax K-100d problema autofocus teo030794 Photographic Technique 1 05-09-2010 02:53 PM
All times are GMT -7. The time now is 10:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
