06-14-2011, 09:52 AM   #1
Dropped K2000
I have a K2000 with a 52mm lens. It accidentally fell from the seat in car to the black top on the street.
I only notice a scratch on the outer lens structure. I removed the lens and re-installed it and still no auto focus. Turned it on and off and the result is the same.
Any suggestions from any one who has had the same problem?
Thanks
06-14-2011, 10:20 AM   #2
QuoteOriginally posted by corisco7444 Quote
Thanks
It's going to have to be serviced. You need to get hold of another lens to mount so you can isolate the problem to either the lens or the camera. If it's the lens, it's cheaper to replace it rather than repair it. You can try taking the battery out and resetting the camera to factory defaults, but I doubt if it will do anything. BTW, 52mm is most likely the filter size your lens requires, not the size of the lens itself. I would guess that you have a 18-55 kit lens.
camera, k2000, lens, pentax help, photography
K2000 drops frames occasionally dragonfly Troubleshooting and Beginner Help 4 09-21-2009 01:04 AM
Dropped DA* 16-55 rickconklin Pentax SLR Lens Discussion 9 08-09-2009 10:26 PM
Just dropped in to say Hi! Shantz Welcomes and Introductions 4 07-29-2009 10:43 AM
K2000 Fast Shutter speeds locked out on Flash? pentaxia Pentax DSLR Discussion 5 06-02-2009 12:29 PM
Pentax make tough cameras: I dropped my K-m / K2000 Stefan Carey Pentax DSLR Discussion 12 04-06-2009 11:30 PM
All times are GMT -7. The time now is 07:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
