06-14-2011, 05:34 PM   #1
K-mount Vivitar 70-210 F3.5(kenko) on my pentax K-x
I thank you guys for supporting a newbie.I want to know if I will be able to use K-mount Vivitar 70-210 F3.5(kenko) on my pentax K-x without any trouble.
Thanks
06-14-2011, 05:41 PM   #2
Yes, of course. You will have to change the settings to "Permit aperture Ring". Its one of the setup menu options
06-14-2011, 06:28 PM   #3
QuoteOriginally posted by manishved Quote
Thanks Manish,
How would you rate this lens. I am not even sure if this is an auto or manual lens.(I sound like a newbie isn't it!!)
Cheers
06-14-2011, 07:23 PM   #4
Steinback's Avatar
Do you have one of the Vivitar Series 1 variants, or is it another type of Vivitar 70-210 f/3.5?
http://www.robertstech.com/vivitar.htm
Some Vivitar lenses have a flange protecting the aperture lever that is too large to mount properly in a DSLR. The flange can be unscrewed and cut down to the same size as the flange on a genuine Pentax lens fairly easily.
I have a Series 1 version #1 (Kiron) which performs quite well within its limitations. Optically the lens is excellent, but the lack of an A aperture setting, manual focus, and the inability to transmit focal length data to the camera body while zooming require more attention and user input than a modern DA series lens.
06-14-2011, 08:18 PM   #5
RioRico's Avatar
Out of curiosity, why do you think it is a Kenko lens? Does it maybe have a Kenko filter screwed-onto it? I've noticed many newbs mistaking the filtermaker for the lensmaker!
A better way to identify the lens is to tell us the serial number -- that may indicate the lensmaker. And as mentioned, does it say SERIES 1 on the lens front? If so, GREAT!
camera, k-mount, k-x, pentax, pentax help, photography, vivitar
DA 50-200 vs DA 55-300 vs Vivitar S1 70-210 vs Pentax-A 70-210; Tele-Zoom Comparo PentHassyKon Pentax SLR Lens Discussion 16 04-28-2010 03:40 PM
Vivitar Vivitar Series 1 70-210 (62mm) or Pentax 50-200? DMH Pentax SLR Lens Discussion 23 10-25-2007 08:04 AM
All times are GMT -7. The time now is 06:12 PM. | See also: NikonForums.com, part of our network of photo forums!
