There is a little screw attached on the top hinge. It's for moving the spring loaded top hinge. Use a 000 Philip screw driver to move the hinge downward (DO NOT try to remove the screw). You can also use finger nail to push the hinge down to remove or install the back cover. All the MZ/ZX series back doors are inter-changeable. The date back displays several formats, including date and time. If you don't want it imprinted on film, simply turn it off, i.e., dashed line.
