06-17-2011, 04:27 PM   #1
Adaptall needed?
I just purchased a Tamron-F 28mm 1:2.8 for $5. at a garage sale. The mount looks like a pentax k mount but there is a small tab, held on by phillips head screw, that keeps the lens from sitting flush, preventing mounting. The lens does not say adaptall, but I get the impression that is what is required. Can anyone tell me whether I need an adaptall or should I remove the tab preventing mounting? (I would have removed tab already, but even my smallest phillips head is too big)
Tamron-F 28mm F2.8 Lens Reviews - Fixed Focal Lengths - Pentax Third-Party Lens Review Database
06-17-2011, 05:50 PM   #2
Can you post a pic of the mount?
06-17-2011, 06:34 PM   #3
The tab I reference in original post is between 3 and 4 o'clock on the outside of the lens (not on mount). Thanks.
06-17-2011, 06:42 PM   #4
littledrawe's Avatar
If the tab comes off the side of the mount at a 90 degree angle don't remove it it should line up with the aperture ring on the lens. When you attach the mount to the lens put the aperture ring on the lens in the largest position i.e. f2.8 and then rotate the tab on the mount to line up with the cutout on the lens and twist the mount onto the lens. There are some other posts on the forum that may explain it a little more clearly but the tab has a purpose in the case of K-mounts and all my adaptall lens are adaptall-2 s so that may be different as well. I'm not sure about other brands of cameras and their respective mounts though.
06-17-2011, 06:46 PM   #5
after looking at your picture and my lens it doesn't look like the same mount.
06-17-2011, 07:05 PM   #6
Blue's Avatar
Tamron had more than one interchangeable mount system. In addition to the Adaptall/Adpatall-2, they had the F system and prior to that they had the adaptamatic. That 28 you linked is the F system. That looks like it could be a Minolta MD or MC mount.
06-18-2011, 05:12 AM   #7
That is a Minolta mount for the old film cameras. It will not work properly on a Pentax DSLR.
06-18-2011, 08:42 AM   #8
Blue's Avatar
I don't know if Tamron ever made an F-mount for the F series lens, but if they did it would be hard to find. The m42 mount is hard enough. Ironically, I saw the Adaptamatic version of that lens in a thrift shop yesterday with the Pentax II version of the screwmount on it. They had a price of $19.99 on it. I nearly bought just to get the mount. That version supports open aperture metering on the Spot F, ES and ES II bodies with later Adaptamatic lenses. The Adaptamatic 28, F 28 and Adaptall were the same optically.
F version
http://www.adaptall-2.org/brochures/F-System/F-System_page5_300dpi.jpg
http://www.adaptall-2.org/brochures/F-System/F-System_page2_300dpi.jpg
Adaptall Version
http://translate.google.com/translate?hl=en&sl=ja&u=http://www.tamron.co.jp/...-lens/cw28.htm
Adaptall-2 version
http://www.adaptall-2.org/lenses/02B.html
06-18-2011, 08:50 AM   #9
RioRico's Avatar
The mount pictured is Minolta MD.
06-18-2011, 09:41 AM   #10
110% Minolta Mount
06-18-2011, 05:36 PM   #11
Thank you everyone for the replies.
06-18-2011, 06:18 PM   #12
What a great wealth of experience is found here!
maybe you can alter the mount to use the lens. I was successful in converting a minolta md to a pentax k by replacing the minolta bayonet with an inexpensive flange type PK-m42 adapter.
06-19-2011, 11:01 AM   #13
RioRico's Avatar
QuoteOriginally posted by newarts Quote
I have had several fine MC/MD's that I didn't muck with because a relative entrusted me to sell them. But I bought a cheap Kiron-made MD-mount zoom for the purpose of seeing if I could convert MD to PK, so I could buy the Rokkors myself. I found that maintaining aperture control on the test-bed lens just didn't work. Also, the MD register is 2mm shorter than PK, so some metal-shaving would be needed.
I'm sure the Rokkors *could* be converted. I'm just not sure how easily, nor with how much functionality. Yeah, I'd love to put the remaining Tele-Rokkor-PF 100/2.5 on my K20D. But, dare I?
06-19-2011, 11:55 AM   #14
Blue's Avatar
The F series Tamron lenses have interchangeable mounts. There are m42 mounts available, just hard to find. The adaptamatic mounts are easier to find than the F series.
28mm, adaptall, head, lens, mount, pentax, pentax help, phillips, tab, tamron-f
Can I use the first generation Adaptall adapter on an Adaptall-2 lens? GibbyTheMole Pentax SLR Lens Discussion 5 12-13-2011 03:38 PM
Tamron Adaptall & Adaptall 2 Mount: What's The Difference? minahasa Pentax SLR Lens Discussion 5 04-20-2011 07:26 AM
Adaptall-2 advice needed (90mm and TC) Diffusion Pentax SLR Lens Discussion 5 01-31-2010 03:22 PM
Help Needed: Tamron Adaptall Aperture Mechanism ballgofar Pentax SLR Lens Discussion 3 07-02-2009 10:10 AM
Tamron adaptall macro help needed: Levi Pentax SLR Lens Discussion 8 06-28-2008 07:28 PM
All times are GMT -7. The time now is 02:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
