06-18-2011, 07:17 AM   #1
spotmatic user's manual
I get a spotmatic film camera but don't know its model and how to use.Where can I find user's manual?
Thank you!
06-18-2011, 07:24 AM   #2
stevbike's Avatar
QuoteOriginally posted by bork2005 Quote
Thank you!
You can do a google search for a PDF file on line. Try this site, http://www.butkus.org/chinon/pentax/pentax_spotmatic_ii/pentax_spotmatic_ii.htm. Otherwise, you can get a book of the basics of photograghy. It will give a good starting point to start using you camera. By the way the Spotmatic is a great film camera. Enjoy using it!!
06-18-2011, 07:27 AM   #3
Here you go.
PENTAX MANUALS
06-18-2011, 11:42 AM   #4
bobva's Avatar
Thanks for the link
06-19-2011, 06:05 AM   #5
Thanks for STEVBIKE and JeffJS! I got it.
06-20-2011, 01:44 AM   #6
How to connect hot shoe flash to Spotmatic?
I make it clear that what I got is a HONEYWELL SPOTMATIC film camera. It has both F and X flash connecting outlet.The problem is what kind of flash fit them,e.g. I have a hot shoe electronic flash with PC line.May I use it?To which hole,F or X?
Thank you for your kind instruction.I checked user's manual there is not any clear instruction.I think it is because the manual were written scores of years ago.
06-20-2011, 05:41 AM   #7
Use the X sync and make sure your shutter speed is set to whatever the x sync speed is Usually 1/60 or 1/30, something like that. Check your manual and look for flash synchronization. Use the wrong flash sync and you'll have half black photos.
06-20-2011, 07:39 AM   #8
Unfortunately, as I'm sure you are aware, the Spotmatic has no hotshoe for flash.
To attach a flash to your camera, you will need a bracket and a synch cord appropriate for your flash.
They made a small bracket that clipped over the viewfinder eyepiece. They are really quite flimsy and would only hold the smallest flash. They appear on ebay quite frequently.
There are many other brackets. One of the most popular, back in the day, was an L-shaped bracket that was hinged for storage. It screwed into the tripod socket and had an accessority shoe on top. These were usually NOT hotshoes, however. That is, there was no electrical contact for flash sync. These also appear on ebay.
Then, you need to connect the flash sync to the camera, somehow. Some flashes either have a sync cord, know as a PC (for Prontor-Contax, the inventor) cord, or have the option of adding one. There are also adapters that will fit into the cold shoe on the bracket and provide the hotshoe connection, via a PC cord.
Then, there are the Honeywell Strobonar "potato mashers". These are available on ebay all the time. Just be careful to get one with good batteries and a charger. These have a large, vertical handle and a bracket that screws into the tripod socket. Most have a quick release latch that attaches the flash to the bracket. I like this one, because I could detach the flash and hold it up, at arm's length above my head, to avoid red-eye, or bounce it off a wall or ceiling.
BTW, just in case you didn't know, always use the X-sync socket on the camera and always set the shutter speed at 1/60 or slower. This is the maximum synch speed for electronic flash.
06-21-2011, 05:46 AM   #9
QuoteOriginally posted by JeffJS Quote
JeffJS,thak you very much!
06-21-2011, 06:08 AM   #10
QuoteOriginally posted by noblepa Quote
Then, you need to connect the flash sync to the camera, somehow. Some flashes either have a sync cord, know as a PC (for Prontor-Contax, the inventor) cord, or have the option of adding one. There are also adapters that will fit into the cold shoe on the bracket and provide the hotshoeThen, there are the Honeywell Strobonar "potato mashers". These are available on ebay all the time. Just be careful to get one with good batteries and a charger. These have a large, vertical handle and a bracket that screws into the tripod socket. Most have a quick release latch that attaches the flash to the bracket. I like this one, because I could detach the flash and hold it up, at arm's length above my head, to avoid red-eye, or bounce it off a wall or ceiling.
noblepa,thank you so much for your detailed instruction. Well,I would use my electronic hotshoe flash as off camera lighting(maybe buy one or more brackets to fix it ),using PC cord connecting to X socket.The shutter will be 1/60 or slower. On-camera flash always can not get good lighting.I think this will work.Am I right?
Frankly speaking I like this forum much more because I find that I can get what I want to know very quickly.
camera, pentax help, photography, spotmatic
K5 - A Canon User's Perspective geezer52 Pentax K-5 27 03-03-2011 06:57 AM
Missing user's manual in the K-5 box henkemann Pentax K-5 16 12-21-2010 11:25 AM
Gday Fellow Pentax User's Craig66 Welcomes and Introductions 4 09-03-2010 10:49 AM
Pentax user's in Sydney??? LiveNLearn Travel, Events, and Groups 32 06-07-2010 07:12 AM
K10D user's manual is now online Ole Pentax DSLR Discussion 6 10-28-2006 10:04 PM
All times are GMT -7. The time now is 08:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
